^lots of loctite was a ***** to get mine off from the factory ended up having this mobile mechanic come by with a 100 gallon air compressor and torching it to break the bolt loose.
I tried the pipe and leverage thing on a car when impact wasn't available, failed. If things are still hooked up.. I'm all about the starter trick. Just be careful because you can get hurt.
Unhook the 7mm bolt holding the coil pack connector to the ICM. That will disable the motor from actually starting.
Da fuq?
Never heard of that unless he means use the jack pole on the end of the breaker bar
