Thread: cylinder #2 missfire
Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
  1. #21 Re: cylinder #2 missfire
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    S/C engine runs 8.5:1 compression where a N/A runs 9.4:1
    More power to be had from a top swapped N/A block with a smaller pulley if you do it right. If I have to do my engine again, I am going to put my cam in a N/A block and top swap it. You have to get someone that can tune very well and tell them you are a topswapped N/A block because the higher compression can make it a bomb if not done right.
    Like Scotty said, top swap a N/A block and put a 4.0" supercharger pulley on it, or since you'll have it all apart, maybe cam it if you want and run headers and stiffer valvesprings and all the fun stuff that go with that =]
    Sent from my SM-N900P using Tapatalk
  2. #22 Re: cylinder #2 missfire
    GT Level Member Trett93's Avatar
    Jun 2014
    Ontario Canada
    so n/a is faster than sc? is that what youre saying? lol
  3. #23 Re: cylinder #2 missfire
    no. a n/a block with l67 supercharged heads lim and blower is faster then a stock l67
  4. #24 Re: cylinder #2 missfire
    Jun 2014
    Ontario Canada
    so, i get it, n/a block and pistons with my sc, heads, and headers, but how do the pistons hold up when they arent meant to take the high hp?
  5. #25 Re: cylinder #2 missfire
    http://www.grandprixforums.net/threa...s-of-3800-Info this is the top swap thread. your doing the reverse, a bottom swap. same rules apply.
  6. #26 Re: cylinder #2 missfire
    Quote Originally Posted by trett93 View Post
    they hold up just fine. people cam, do head work, ic and pulley down pretty good. its still a 3800 just hi compression. why you need headers to do this.
    n/a guys also turbo the n/a blocks. they hold up just fine.
  7. #27 Re: cylinder #2 missfire
    Jun 2014
    Ontario Canada
    ohhhh so you want me to get the n/a pistons from an l67 and put it in my l67 sc LOL blonde moment, been a long day at work, need to slam some gears haha
  8. #28 Re: cylinder #2 missfire
    no buy a n/a block, take the heads off it, then put your l67 heads and lim, blower pulleys on the n/a block. done deal.
    the blocks are the same on the out side, everything just swaps over.
  9. #29 Re: cylinder #2 missfire
    Jun 2014
    Ontario Canada
    well thanks for the info! whenever i can afford to not have the car on the road ( winter time) ill consider a build, sounds like it would be fun, how does only one cylinder get a spark knock? unless its not getting proper fuel (injector)?
  10. #30 Re: cylinder #2 missfire
    who knows? but no compression is no compression. aka dead engine.
    you can pop the vc's off look for a bad spring or bent push rod, crank the engine vc's off watch that the rockers all move the same.
    id do this before doing anything yet to make sure its a dead piston and not something fixable.
  11. #31 Re: cylinder #2 missfire
    Jun 2014
    Ontario Canada
    yeah and alot cheaper for gaskets and less time for tear down,
  12. #32 Re: cylinder #2 missfire
    any vids or pics of this car. seems like a off the wall engine swap. very different for sure.
  13. #33 Re: cylinder #2 missfire
    Jun 2014
    Ontario Canada
    i can add some later, i mainly go on this at work, and all my pictures are on my phone, its a sick car haha, ill add some after
  14. #34 Re: cylinder #2 missfire
    Jun 2014
    Ontario Canada
    there uploaded a picture to my signature
    3800 series 2 SC swap, 180 tstat, 5 speed swap, stage 3 clutch, machined camaro flywheel,
    s1x cam, rollmaster double roller, crow cams 105# springs, TR6's, overkill tune, ssbc big brake kit..more soon.
  1. cylinder #2 missfire
    By Trett93 in forum Introductions/Noob Questions
    Last Post: 06-09-2014, 11:24 AM
  2. 04 gtp cylinder #3 missfire
    By slgrnvlfire in forum General Grand Prix Discussion
    Last Post: 08-18-2013, 12:52 PM
  3. 01 every cylinder missfire.
    By jbb421 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2013, 06:31 AM
  4. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  5. Coding cylinder 3 missfire and cylinder 3 injector port open
    By MATHEWSMAN1969 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2010, 04:27 PM
