Thread: 01 every cylinder missfire.
Results 1 to 7 of 7
  1. #1 01 every cylinder missfire.
    Feb 2013
    Tennessee
    My buddies 01 gp is misfiring on every cylinder, but is only throwing a code for cyl 1 misfire it also stops missing as soon as you apply any throttle. Also here is this hope it helps. plugs are also factory gapped, and has a new reman injector on cyl 1... I checked all the valves when i put headgaskits on it they seemed to be fine, no signs of burning and didn't leak at all. Thanks! hope y'all can ease our headache.
  2. #2 Re: 01 every cylinder missfire.
    Have you triple checked the firing order and ensured the coils if labeled are in the proper places?
  3. #3 Re: 01 every cylinder missfire.
    Feb 2013
    Tennessee
    Yup firing order is good. I've checked it probably 20 times, and even put a new coil temporarily in place of the 1&4 coil to see if that was the issue. Even though 4 isn't missing as much as 1.
    Thanks for the reply.
  4. #4 Re: 01 every cylinder missfire.
    St. Louis
    Have a spare ICM laying around?
  5. #5 Re: 01 every cylinder missfire.
    tennessee
    how long after head gasket change did this happen??? improperly sealed gasket??? just suggestions but compression test may be in order
  6. #6 Re: 01 every cylinder missfire.
    Feb 2013
    Tennessee
    wouldn't it be loosing coolant if it was a head gasket? and im sure we can get one try it and return it fordman... Guess ill do compression test tomorrow... what #s should be expected?
  7. #7 Re: 01 every cylinder missfire.
    ~180psi. =/- about 5% is acceptable.
    You know.. I have seen something screwy like this in the past. Try a crank learn. aka case learn.
  1. missfire HELP!!
    By Will5600 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2014, 10:25 PM
  2. Missfire
    By Enzo354 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-07-2011, 09:26 PM
  3. gtp missfire
    By mtz956 in forum General Tech Discussion
    Last Post: 12-24-2010, 10:58 AM
  4. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  5. Coding cylinder 3 missfire and cylinder 3 injector port open
    By MATHEWSMAN1969 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2010, 04:27 PM
