Thread: Spark plug Reviews
Page 1 of 3 123 LastLast
Results 1 to 20 of 45
  1. #1 Spark plug Reviews
    GT Level Member bayareagtp's Avatar
    Milpitas , Ca.
    Ok let hear what everyone has and what everyone prefers for their spark plugs and also let us know what kind of car they are in race or daily driver and so on .
    1998 GTP , 3" down pipe w/cat , u-bend delete , full 3" exhaust w/ magnaflows , no resonator , powerslot front rotors , Overkill PCM , Overkill FWI , 180* t-stat , 1* colder plugs , alt. re-wire , alt. stage 1 booster . 215 whp and 238 torque .
  2. #2 Re: Spark plug Reviews
    Topeka, KS
    Autolite 104 Light Racing and Daily Driver.
  3. #3 Re: Spark plug Reviews
    SE Level Member scooz14's Avatar
    West Bloomfield MI
    al 103's
    i beat the **** out of it
  4. #4 Re: Spark plug Reviews
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    I've used. TR6IX, TR55IX, AL103, AL104, AR103's. Daily driver.
    While not much difference between them, my car seems to like the TR6IX a little better as far as smooth idle, mpg. I noticed no difference between any of them as far as KR.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  5. #5 Re: Spark plug Reviews
    Milpitas , Ca.
    i know they are talking about this in another post too but what about brisk ? also what about iridium and some of the quad point plugs ? goods/bads ? i was told autolites 1 degree colder than stock , gaped 55 that is what someone told me to use . daily driver now but soon light racing with more mods .
  6. #6 Re: Spark plug Reviews
    St Louis MO
    Quote Originally Posted by bayareagtp View Post
    .055 is correct. The TR55IX and TR6IX that I mentioned are iridiums. On newer wbodys iridium is factory installed.
    The one this I noticed when doing research on the Brisk is that the quad recommended for a stock GTP also has a foot note about potential blow out. Eventhough they recommend their iridium plugs for higher boosted application, it's not clear what configuration you get, Single, double or triple prong. I am interested in the soon coming review.
    autolite 606 is stock, 605 is one step colder 104 is 2 steps colder and 103 is 3 steps colder than stock.
    2010 Camaro SS LS3
  7. #7 Re: Spark plug Reviews
    Saraland Alabama
    iridium is fine, platinum seems to be an issue. I run autolites never had a problem. I have seen many cars run the multi point plugs and foul them constantly (any quad 4 I ever saw them in they were fouled)
  8. #8 Re: Spark plug Reviews
    Port Hope Ont,Canada
    Norm would be a Autolite 104's
    But am trying out the BRISK GOR15LGS
    same heat range as the 104's and a very impressive plug.
    I have used 104's, 103's TR6, TR5's
    1998 GTP, U-Bend Delete,Hi-Flow Cat,No Res,SLP Headers,BRISK Plugs ,180 T-Stat, 3.4 pully
    2007 GM Show and shine August 10http://www.youtube.com/v/aRh91q1jRio&rel=1
    OQCGP Clubhttp://www.youtube.com/v/j_YHmgU9ehs&rel=1
  9. #9 Re: Spark plug Reviews
    GT Level Member Going Too Phast's Avatar
    Quote Originally Posted by IndeedSS View Post
    605 is stock, 104 is one step colder and 103 is 2 steps colder than stock.
    Actually, I believe AL 606's are equivalent to the stock heat range. But 605's are recommended because it can help reduce the factory GTP KR since they are one step colder. So 104's are two steps, 103's three steps, etc.
  10. #10 Re: Spark plug Reviews
    I live here. UR LOSN's Avatar
    Rockford, IL
    AL 103's GTP drag,
    have iridiums in GT now...smooth idle.
    I have had bosch platnium 4's in my old 95 SE....it hated them...burned out.
  11. #11 Re: Spark plug Reviews
    St Louis MO
    Quote Originally Posted by Going Too Phast View Post
    you are right. DOH!
    2010 Camaro SS LS3
  12. #12 Re: Spark plug Reviews
    St Louis MO
    I emailed BRISK about what plug to use on a mildly modded 3.8l s/c V6 with about 11PSI, and got this response today:
    Hi Lee,
    the spark plug you need is Brisk Silver Racing G14YS. That is a spark plug specially designed for forced induction applications, nitrous or methanol injection.... and we have many vehicles with over 3500Hp running the Brisk Silver Racing plugs and setting world records. The LGS is excellent choice for N/A and stock boost forced induction applications. Your vehicle have powerfull ignition system and will handle the GOR14LGS plug at your boost level, but due to the higher boost and altered A/F ratio the lifespan of the plug will be relatively short.
    Hope this info will help.
    Best regards,
    Chris
    EDIT: I noticed the plugs Brisk recommended are NOT resistor plugs. I've emailed back for verification. But on a car ran by computer electronics, this is probably not a good idea.
    2010 Camaro SS LS3
  13. #13 Re: Spark plug Reviews
    GT Level Member SD GTP's Avatar
    Kirkwood, Delaware
    I'm using AL Platinum 104s gapped at .55 Cars likes 'em and I've never had a problem with them. I ran AL 605s in my old 97 GT.
    Kind of on the same subject, if anyone here is using Taylor Wires, I would not recommend them. I found them to be the source for misfires and bad connections when I had them on my GT. also, the connectors liked to break when I changed plugs. I've heard the MSDs are a solid choice if anyone is looking for a solid set up.
    MACGP President
    3.25"/P&P Gen III/ZZP Stg II TB/Thasher CAI/ZZP VS Cam/TOG Xtremes/AL 104s/180*/Full 3" Exhaust/SD Package/GMPP Sways & Arms/DuBob'd
  14. #14 Re: Spark plug Reviews
    SE Level Member AlphaBetaBase's Avatar
    I always questioned the 4's from a logical standpoint.
    An arc goes to the path of least resistance so it will always go to one of the four points. Yea, if the good point becomes foul it has 3 others to choose from. Problem one doesn't become foul on its own. Therefore, I never bought them.
    Mine are 103s. Daily driver. Had Bosch iridiums before when I was N/A. No issues with either.
  15. #15 Re: Spark plug Reviews
    Quote Originally Posted by SD GTP View Post
    I had 8mm MSDs on mine. I noticed a slightly better throttle response but that's it. I've heard they don't last long but I didn't experience any problems.
    Everyone told me to only use stock when it comes to the GPs ignition i.e., wires, coils. No aftermarket compares to it.
  16. #16 Re: Spark plug Reviews
    SE Level Member Blue03GTP's Avatar
    Wi
    Can somebody school me on going to a colder plug from stock? Thanks.
    Blue 2003 Limited Edition.
  17. #17 Re: Spark plug Reviews
    GTX Level Member webracin's Avatar
    Arkansas
    This is some info I tried to compile a while ago.....
    97-03 Grand Prix
    Manufacturer/Type < < < Colder Stock Hotter > > >
    AC Delco
    Copper 41-919 41-932 41-921
    Platinum
    Double Platinum
    Iridium 41-985 41-101
    Autolite
    Copper 104 605 606
    Platinum AP606
    Double Platinum APP606
    Iridium
    Bosch
    Copper 7580
    Platinum 6241
    Double Platinum 4304
    Iridium
    Denso
    Copper
    Platinum
    Double Platinum PT16ETR-L13
    Iridium IT16
    NGK
    Copper TR55
    Platinum TR55GP
    Double Platinum PTR4B-15
    Iridium TR7IX TR6IX TR55IX
    Platinum is not recommended for engines with power adders.
    Nice info on why to run colder plugs and what it means... Spark Plug Info
    webracin
    2001 Grand Prix GTP
    ZZP HUB 3.2 3.4, ZZP 8 Rib conversion, JC 3" DP Gen 2 cat & U-bend Delete, Accel Super Stock 8mm wires, DHP 1.5, 180* Thermo, Throttle Spacer, SS Intercooler, ZZP Fuel Rails, SLP CAI w/K&N Cone, Dynomax cat back, ZZP Tranny.
    2000 Grand Prix GTP Daytona K&N, Flowmasters
  18. #18 Re: Spark plug Reviews
    St Louis MO
    Chis on the NGK, the stock replacement iridium is the TR55IX.
    Although you are not supposed to gap iridium plugs here is a how-to for those like me who can't leave good enough alone. Installation Guide: DENSO Iridium
    Last edited by IndeedSS; 01-11-2008 at 08:55 PM. Reason: added a link for iridium gapping
    2010 Camaro SS LS3
  19. #19 Re: Spark plug Reviews
    GT Level Member shaferz's Avatar
    Forrest IL
    I run 103's right now, but over the summer last year I ran TR8's since I was spraying so much. My car seemed to like them quite a bit. Definate decrease in KR, and I changed the plugs whenever I did an oil change to keep them fresh.
    99 GTP = 12.936 @ 112.12 2.16 60'
    06 TBSS = STOCK
    07 GXP = STOCK - ordering SSC's
  20. #20 Re: Spark plug Reviews
    Arkansas
    must have fat fingered that one.....
    Also added a link to some good info on what and why on colder plugs.
    webracin
    2001 Grand Prix GTP
