I get those from ZZP. I've looked for them on the Internet, but haven't found them any cheaper. One thing to note and I've mentioned it before. The stock replacement plugs TR55IX are gapped at the factory .059, but the TR6IX are .039. You are NOT supposed to gap iridium plugs, but of course .039 isn't going to get it. I gapped mine by using 2 separate flat metal feeler gauges NOT the wire type. I used the .035 from one gauge and the .020 from the other and staggered them. Like this -_ This way I could clear the center electrode tip first, without accidently nicking the iridium coating and then gently slide it the rest of the way in to check the gap. Obviously when adjusting the ground electrode you have to position the gap tool so that it will not tough the insulator or center electrode ever. (I used the gapper found on a wire type gauge, do NOT check gap or adjust the ground electrode with one of those modern day progressive disc gauges). I gapped to .055, installed the plugs to spec, put a thin layer of dielectric grease on each plug before connecting the wires, and fired it up. It definitely started a lot quicker than I've been used to lately. The idle still hops (XP cam), but it seems a little less erradic. I will need to drive a few more days to make any further determinations.
