Ok let hear what everyone has and what everyone prefers for their spark plugs and also let us know what kind of car they are in race or daily driver and so on .
Autolite 104 Light Racing and Daily Driver.
I've used. TR6IX, TR55IX, AL103, AL104, AR103's. Daily driver.
While not much difference between them, my car seems to like the TR6IX a little better as far as smooth idle, mpg. I noticed no difference between any of them as far as KR.
i know they are talking about this in another post too but what about brisk ? also what about iridium and some of the quad point plugs ? goods/bads ? i was told autolites 1 degree colder than stock , gaped 55 that is what someone told me to use . daily driver now but soon light racing with more mods .
.055 is correct. The TR55IX and TR6IX that I mentioned are iridiums. On newer wbodys iridium is factory installed.
The one this I noticed when doing research on the Brisk is that the quad recommended for a stock GTP also has a foot note about potential blow out. Eventhough they recommend their iridium plugs for higher boosted application, it's not clear what configuration you get, Single, double or triple prong. I am interested in the soon coming review.
autolite 606 is stock, 605 is one step colder 104 is 2 steps colder and 103 is 3 steps colder than stock.
iridium is fine, platinum seems to be an issue. I run autolites never had a problem. I have seen many cars run the multi point plugs and foul them constantly (any quad 4 I ever saw them in they were fouled)
Norm would be a Autolite 104's
But am trying out the BRISK GOR15LGS
same heat range as the 104's and a very impressive plug.
I have used 104's, 103's TR6, TR5's
AL 103's GTP drag,
have iridiums in GT now...smooth idle.
I have had bosch platnium 4's in my old 95 SE....it hated them...burned out.
I emailed BRISK about what plug to use on a mildly modded 3.8l s/c V6 with about 11PSI, and got this response today:
Hi Lee,
the spark plug you need is Brisk Silver Racing G14YS. That is a spark plug specially designed for forced induction applications, nitrous or methanol injection.... and we have many vehicles with over 3500Hp running the Brisk Silver Racing plugs and setting world records. The LGS is excellent choice for N/A and stock boost forced induction applications. Your vehicle have powerfull ignition system and will handle the GOR14LGS plug at your boost level, but due to the higher boost and altered A/F ratio the lifespan of the plug will be relatively short.
Hope this info will help.
Best regards,
Chris
EDIT: I noticed the plugs Brisk recommended are NOT resistor plugs. I've emailed back for verification. But on a car ran by computer electronics, this is probably not a good idea.
I'm using AL Platinum 104s gapped at .55 Cars likes 'em and I've never had a problem with them. I ran AL 605s in my old 97 GT.
Kind of on the same subject, if anyone here is using Taylor Wires, I would not recommend them. I found them to be the source for misfires and bad connections when I had them on my GT. also, the connectors liked to break when I changed plugs.I've heard the MSDs are a solid choice if anyone is looking for a solid set up.
I always questioned the 4's from a logical standpoint.
An arc goes to the path of least resistance so it will always go to one of the four points. Yea, if the good point becomes foul it has 3 others to choose from. Problem one doesn't become foul on its own. Therefore, I never bought them.
Mine are 103s. Daily driver. Had Bosch iridiums before when I was N/A. No issues with either.
I had 8mm MSDs on mine. I noticed a slightly better throttle response but that's it. I've heard they don't last long but I didn't experience any problems.
Everyone told me to only use stock when it comes to the GPs ignition i.e., wires, coils. No aftermarket compares to it.
This is some info I tried to compile a while ago.....
97-03 Grand PrixManufacturer/Type < < < Colder Stock Hotter > > >
AC Delco
Copper 41-919 41-932 41-921
Platinum
Double Platinum
Iridium 41-985 41-101
Autolite
Copper 104 605 606
Platinum AP606
Double Platinum APP606
Iridium
Bosch
Copper 7580
Platinum 6241
Double Platinum 4304
Iridium
Denso
Copper
Platinum
Double Platinum PT16ETR-L13
Iridium IT16
NGK
Copper TR55
Platinum TR55GP
Double Platinum PTR4B-15
Iridium TR7IX TR6IX TR55IX
Platinum is not recommended for engines with power adders.
Nice info on why to run colder plugs and what it means... Spark Plug Info
webracin
Chis on the NGK, the stock replacement iridium is the TR55IX.
Although you are not supposed to gap iridium plugs here is a how-to for those like me who can't leave good enough alone. Installation Guide: DENSO Iridium
Last edited by IndeedSS; 01-11-2008 at 08:55 PM. Reason: added a link for iridium gapping
I run 103's right now, but over the summer last year I ran TR8's since I was spraying so much. My car seemed to like them quite a bit. Definate decrease in KR, and I changed the plugs whenever I did an oil change to keep them fresh.
must have fat fingered that one.....
Also added a link to some good info on what and why on colder plugs.
webracin
