Thread: problem after header install
Results 1 to 20 of 27
  1. #1 problem after header install
    Florida
    After my friend and I installed my SD headers I took it for quick drive. After roughly 2 min car started surging and almost dying. So came back and we scanned it, and codes p0136 and p0141 popped up. Both point to front bank o2 sensor. I can't remember anything bad I did other then maybe when I twisted it trying to reinstall I may have damaged it? But then today same thing occurred but 3 other codes popped up p0030,0131, and 0135. Same issue car surges for a few and acts like it wants to die. I also have the zzp o2 sensor extension for the front, could that be defective or should I just replace the front o2 sensor?
  2. #2 Re: problem after header install
    Did you use an extension harness or did you make your own?
    oops missed the part where you said you had the extension harness sorry
    You might have damaged the wires in the 02 sensor like you are thinking, that is the only thing I can really think of. Just run to Napa and get a new Denso 02 sensor.
  3. #3 Re: problem after header install
    Florida
    zyea ill do that. It may have been when i twisted it i forgot to unhook from original harness and the wires twisted and may have damaged some. I also sprayed pb blast on it to get it off i dont know if that matters. didnt get too much on sensor though.
  4. #4 Re: problem after header install
    Feb 2013
    Detroit, MI
    I sprayed a bunch of pb blaster as well n didn't have problems, may have twisted a wire loose, take it off n check it before ya buy a new one even.
  5. #5 Re: problem after header install
    The Boss Iceman6669's Avatar
    Jun 2011
    Stupid question but you did make sure the O2 extension isn't laying on the headers right?
    2011 F-150 Yote powered
  6. #6 Re: problem after header install
    Florida
    well its not stupid since i didnt exactly double check to.make sure it wasnt touching.i did have it tucked somewhere since it has so much extra slack. ill double check soon.
  7. #7 Re: problem after header install
    Oct 2011
    Puyallup WA
    Had to replace my front o2 after my header install just grab a new one clear the codes and go from there
    08 G8 GT - exhaust Tune
  8. #8 Re: problem after header install
    Florida
    Found the issue,it was my extension harness being welded/melted from touching headers lol. Good call iceman.
  9. #9 Re: problem after header install
    Just use some solder, heat shrink and some electrical tape.
  10. #10 Re: problem after header install
    Florida
    nah i think im good,rather order a new one unless somebody near me can do that.lol
  11. #11 Re: problem after header install
    a soldering kit would cost under the cost of a new harness. and you now have it forever.
  12. #12 Re: problem after header install
    Florida
    Do i need to necessarily solder? I was told i can get away by just twisting them good and use electrical tape plus heat shrink,and would it be ok if i ran my front o2 unplugged for a few days til i resolve this? i work 4 days straight.
  13. #13 Re: problem after header install
    GTX Level Member 98buicksupercharged's Avatar
    Oct 2012
    Fort Wayne, Indiana
    Don't be scared to solder. It's simple and easy.
    2001 sliver gtp her name is Reagan
  14. #14 Re: problem after header install
    Go grab a cheapo solder gun from HF and solder it. That way the connection is solid and will not break easiky
    04 Comp G.
  15. #15 Re: problem after header install
    Jun 2011
    Glad you got it sorted out... Mine acted funny after header install.. Turned out mine was sitting on my headers too, that's why I asked.
  16. #16 Re: problem after header install
    Quote Originally Posted by dmahlikGT View Post
    oh dear lord, who ever told you that, find them, then smack them lol
    HF iron is like 3 bucks, (10 at sears) solder at the shack is 5 bucks, you want flux core solder, its thin and in a tube. then HF shrink tubes are 3 bucks for a huge ass assorted box. or 5 or so at the shack for way less of them.
    you tube show to solder, theres nothing to it.
  17. #17 Re: problem after header install
    Florida
    Aight guys lol. But again i won't have much time til the end of the week so could i get away with having my o2 unplugged til then?
  18. #18 Re: problem after header install
    dont think your engine will like that to much. you could do the twist and tape as a temp fix till you can do it the right way later this week.
  19. #19 Re: problem after header install
    It would take all of 5 min to fix it.
  20. #20 Re: problem after header install
    ... osiris94ej's Avatar
    Sep 2012
    Casper Wyoming
    I would rather use butt connectors over twisting and taping for a temp fix.
  1. TOG header install
    By 2001goldGTP in forum General Tech Discussion
    Last Post: 12-16-2010, 11:17 AM
  2. Header Install
    By chrisgsx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-07-2010, 05:22 PM
  3. Header Install
    By GP_Kid18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2009, 11:12 PM
  4. S&S Header Install
    By GRANDPRIXFOOL01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2009, 09:57 PM
  5. OBX Header Install is Done!!
    By Uno99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2009, 12:43 PM
