Thread: Header Install
Results 1 to 20 of 24
  1. #1 Header Install
    SE Level Member chrisgsx's Avatar
    Nov 2010
    Michigan
    I have a 99 Grand Prix gtp and i'm trying to figure out the easiest way to install the headers, ive searched and cannot find an exact write up. I have the engine out right now. Would it be easier to put them on, then install the engine? Or should i wait until the engine is in? Any help would be great! Thanks
  2. #2 Re: Header Install
    Nov 2009
    Grand haven
    now for sure. Less the DP.
  3. #3 Re: Header Install
    GT Level Member tdm571's Avatar
    Lakeside Park, KY
    Your best bet is to look at the top swap write up as that is essentially what you are taking off and putting on.
  4. #4 Re: Header Install
    Nov 2010
    Michigan
    Thanks for the quick reply. Any other input? Do you have the link for the full write up?
  5. #5 Re: Header Install
    SE Level Member Vlad0691's Avatar
    Dacula, GA
    Speed Daddy Header install writeup - General Tech Discussion
    There's that ^^. Idk how much iit'll help you if you have different headers, but it should at least give you a general idea. Good luck! Took me a lot of time, sweat, and anger to get mine in hahaha.
    CAI, 180* T-Stat, SD Headers, EGR Delete
    I have hazy headlights <3.
    R.I.P.
  6. #6 Re: Header Install
    Nov 2010
    Michigan
    Those are the exact one i bought. Thanks for the quick reply guys
  7. #7 Re: Header Install
    Best bet is to lay the rear header in place. As you bring the engine in and it's still floating, hook up the two ends (studs with nuts) and then you can finish it off easily after the engine is in place.
  8. #8 Re: Header Install
    GT Level Member starscream5000's Avatar
    Kentucky
    Getting the transmission dipstick bent just right and back in was the biggest pain on my SD header install. Specifically getting the little 10mm bolt back int, that was a PITA.
    2005 GTP - AL 605's gapped at .055", SD headers, WAI with 9" cone air filter, 180 degree t-stat, green coolant, otherwise stock.
  9. #9 Re: Header Install
    Take the fans out...makes a CAKE of an install if you've got ratchet straps on it...which you should...it makes life way easier.
  10. #10 Re: Header Install
    Charles City, IA
    Leave fans in, remove lower engine mount nuts.
    SMGPFC Two Nipple General
  11. #11 Re: Header Install
    ^^Too much work LOL
  12. #12 Re: Header Install
    Nov 2009
    Grand haven
    I agree with NICK on this one!
  13. #13 Re: Header Install
    Charles City, IA
    ^^Too much work LOL
    How is take 2 nuts off the bottom of the subframe harder than pulling the fans?
  14. #14 Re: Header Install
    be lazy like me and pay someone to do it...lol
  15. #15 Re: Header Install
    you dont need to do either.
    just remove the tranny dip stick and it will be all gravy.
  16. #16 Re: Header Install
    Dacula, GA
    Remore the EGR too, it'll be in the way. Speaking from experience haha.
    R.I.P.
  17. #17 Re: Header Install
    no egr makes brake booster swap easy.
  18. #18 Re: Header Install
    Guys...I've installed three sets of these. Someone please tell me why you want to take out the dipstick tube for the trans. Why you want to ratchet the motor forward while it's out of the car and why this is so difficult?
    I've never worried about a dipstick tube. These aren't togs. Those are the only ones I've had issues with dipstick bending.
  19. #19 Re: Header Install
    Nov 2009
    Grand haven
    I think bill is correct on the tog's.
  20. #20 Re: Header Install
    well after reading yeah... just put the rear header in then drop the engine in and put the crossover and front mani on
  1. SD Header Install Soon...
    By theshznt69 in forum 04+ Specifics
    Last Post: 05-23-2010, 05:28 PM
  2. ZZP Header Install
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2010, 09:08 PM
  3. Header Install
    By GP_Kid18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2009, 11:12 PM
  4. my header install needs help
    By gtphayes in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2009, 04:57 PM
  5. OBX Header Install is Done!!
    By Uno99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2009, 12:43 PM
