Thread: problem after header install
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: problem after header install
    Quote Originally Posted by osiris94ej View Post
    I would rather use butt connectors over twisting and taping for a temp fix.
    as much as i hate but connectors, for a temp fix i agree.
  2. #22 Re: problem after header install
    ... osiris94ej's Avatar
    Sep 2012
    Casper Wyoming
    Yea, I solder everything.
  3. #23 Re: problem after header install
    Mar 2012
    South Beloit, IL
    Just my personal experience, the steel wires of the O2 sensor do not accept solder at all. I am pretty good at soldering, I cleaned the contacts and used flux. The copper wire I used to extend it saturated in solder, but the steel wires wouldn't at all.
  4. #24 Re: problem after header install
    if the extension harness is copper it will work. but if ss like you said they wont solder, then your stuck using a butt connector, and some shrink tubes.
  5. #25 Re: problem after header install
    Florida
    yea i cut the connector off the o2 part and they are silver little wires. the extension has bronze wires.
  6. #26 Re: problem after header install
    May 2012
    Where winter never ends
    I usually solder in two ways:
    1) Tin both wires. put them together like an = sign, heat them up and tap them together. This is very quick easy and very strong.
    2) http://makezine.com/2012/02/28/how-t...asa-standards/ I use this if its something very important, i mean if it holds space ships together It better hold my LED on!
    2000 Regal - Winter Beater
  7. #27 Re: problem after header install
    this is exactly how i like to twist my wires. from that link up top. those are one tough solder joint. you can snap the wire hard and they never fail.
  1. TOG header install
    By 2001goldGTP in forum General Tech Discussion
    Last Post: 12-16-2010, 11:17 AM
  2. Header Install
    By chrisgsx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-07-2010, 05:22 PM
  3. Header Install
    By GP_Kid18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2009, 11:12 PM
  4. S&S Header Install
    By GRANDPRIXFOOL01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2009, 09:57 PM
  5. OBX Header Install is Done!!
    By Uno99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2009, 12:43 PM
