Thread: Modded fuel rails leaking and engine knocking when mashing the gas
Results 1 to 20 of 40
  1. #1 Re: Modded fuel rails leaking and engine knocking when mashing the gas
    Feb 2013
    Detroit, MI
    Mine were leaking because I had to add some barb fittings..i tried pipe sealant n it didn't work. Then I used red loctite, cuz that's what zzp originally used and that worked well. Make sure you let it dry and cure tho. Haven't had a problem since. Was gonna try the tape next if the loctite didn't work.
  2. #2 Re: Modded fuel rails leaking and engine knocking when mashing the gas
    Banned
    Jan 2013
    maryland
    Quote Originally Posted by GrandPrix06GT View Post
    So loctite on the fittings? Or on top of them? I'll try teflon tape but i'll start with loctite
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
  1. Modded fuel rails and engine cover?
    By txslow6 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-01-2012, 10:16 AM
  2. L67 modded fuel rails
    By txslow6 in forum Wanted To Buy - Parts
    Last Post: 02-25-2012, 09:38 AM
  3. WTB: Modded fuel rails for 01 gtp
    By samuelcb409 in forum Wanted To Buy - Parts
    Last Post: 02-09-2012, 07:31 PM
  4. modded fuel rails
    By Taz Magister in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-26-2011, 10:56 PM
