Thread: Timing?
Results 1 to 6 of 6
  1. #1 Timing?
    Mar 2014
    Indiana
    What is the stock timing for an 02 gtp before retard? Would it be feasible to just get a timing gauge and measure the difference to find KR?
    2002 Fully Loaded GTP. Cat back exhaust and 20% window tint all the way around(Rollin in the dark). Soon to be CAI, headers, and high flow cat.
  2. #2 Re: Timing?
    hangover park IL
    too many tables that can pull timing for Tq management/ECT/IAT/AFR etc.
    you would never be able to tell which table was responsible much less whether its due to knock...
    that's why you need to be able to scan the knock retard Pid
    ~James~ Psychotic Gearhead
  3. #3 Re: Timing?
    A scangauge 2 or aeroforce can read both, no need for a seperate gauge.
  4. #4 Re: Timing?
    Stock timing is 16° iirc
  5. #5 Re: Timing?
    Mar 2014
    Indiana
    Alright thanks guys
  6. #6 Re: Timing?
    May 2008
    Schuyler, NE
    As said, a number of factors affect timing. There is no set number. Only way to tell is with a gauge.
  1. double timing vs stock timing chain
    By Dam20735 in forum General Tech Discussion
    Last Post: 05-24-2013, 12:53 PM
  2. To add timing or not...
    By bobeebob in forum PCM Tuning
    Last Post: 12-06-2012, 10:33 PM
  3. Timing
    By redskinman73 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-16-2011, 01:48 AM
  4. N/A Cam timing
    By skidoojames151 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-14-2009, 01:12 AM
  5. Got another timing???
    By GTP4 in forum PCM Tuning
    Last Post: 11-15-2008, 07:38 PM
