How high a KR are you seeing and what size injectors and pulley are you running??
You shouldn't need to use teflon tape on them, but they shouldn't be leaking. I'd take the braided line off, clean all the fittings really well, wrap the male fittings with a little teflon tape, and reinstall. Mine I go until they are snug, then just a little bump, never once had a leak.
Those IC lines aren't being pinched ontop of the coil pack are they? First spin I took after my IC install, I hadn't purged all the air out of the IC so it was basically useless. Saw 13* of knock on part throttle. Purged all the air, now I'm seeing 0.
Ok i'll check that thanks bro!
Sent from my SAMSUNG-SGH-I747 using Tapatalk
