Thread: Major Problems-Blown gaskets
Page 4 of 4 FirstFirst ... 234
Results 61 to 80 of 80
  1. #61 Re: Major Problems-Blown gaskets
    HUDSON
    Obviously blew the head gasket. But what is going on with that piston? WHy does the piston look so much different from the top picture? Is that a groove or a crack?
  2. #62 Re: Major Problems-Blown gaskets
    i guess have the heads checked over at a shop. then clean up the old gaskets off, mop up the coolant, oil the cylinders up to help free any rust.
    then run a straight edge over the cylinders and the rest of the deck to look for warped spots, you use a light behind the metal straight edge and look for light under the metal edge, or use feeler gauges.
    you need new head bolts, and gaskets of course.
    if you haven't, keep the rockers and push rods in order so when it goes back together the rockers and its push rod are back in the same spot as before. these parts all wear together and like to be put back where they lived in the past.
  3. #63 Re: Major Problems-Blown gaskets
    Quote Originally Posted by QUICKSILVER462 View Post
    your right, wtf is going on with that one piston?
  4. #64 Re: Major Problems-Blown gaskets
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    It almost looks like a different piston than the rest. At least to me it does. I looked at it for a while and came to the assumption that it looks almost as if it would cause a slightly lower compression because it has less bumped up surface area. But again, not a pro =P
  5. #65 Re: Major Problems-Blown gaskets
    Dec 2012
    Where 4T65E's were born
    My mind is blown, Why do the last 2 pictures look so different with the left piston? One looks fine then in the next pic that same piston looks different
    Sold.
  6. #66 Re: Major Problems-Blown gaskets
    HUDSON
    Yea, that piston in the bottom pic looks different because it is reflecting on the cylinder wall making it look larger in diameter. Talk about optical illusion!
  7. #67 Re: Major Problems-Blown gaskets
    GT Level Member Steven Monteith's Avatar
    May 2012
    Phoenix, AZ
    Sorry guys...the last picture I used a flash and focused on the left piston because that's where the messed up spark plug was. they look a little slugged up because I just gave it a quick wipe down. Yes, I plan on taking the head to a shop. I figure since I have it tore down I might as well take the other head off and send it to the shop as well.
  8. #68 Re: Major Problems-Blown gaskets
    Dec 2008
    Lawndale, CA
    After my brother did his top swap the front head gasket blew. Took both heads to get looked at and it turns out the front head was bad and caused the issue. Now I know why the grand prix we pulled these off of was in the junkyard.
  9. #69 Re: Major Problems-Blown gaskets
    May 2012
    Phoenix, AZ
    I'll be taking both heads to the shop some time soon and was wondering about the valve springs...should I replace them? They have about 20k miles on them or so. Keep in mind I have the xp cam and 105 springs...how about the ls6 lifters???
  10. #70 Re: Major Problems-Blown gaskets
    Mercer, Pa
    I've seen intercooler installs that end up pushing up the dipstick. It's possible to have a boost leak pressurize the crankcase. The way to rule out boost pressure is to take supercharger belt off and go for a test ride. If it doesn't push up the dipstick with belt off you have a leak somewhere.
  11. #71 Re: Major Problems-Blown gaskets
    May 2012
    Phoenix, AZ
    Should I get felpro or acdelco gaskets???
  12. #72 Re: Major Problems-Blown gaskets
    I've been doing some reading on the metal intake gaskets and it seems the delcos use a cheeper looking aluminum and the beads of the seals aren't as thick as the Felpros, now if that actually makes any difference is still up in the air. On Rockauto the Felpros are only like 5 or 6 bucks more than the delcos and they come with new Owings for the fuel injectors.
    Sent from A Galaxy Far Far Away........
  13. #73 Re: Major Problems-Blown gaskets
    May 2012
    Phoenix, AZ
    Finally sent my heads to the shop and everything is good. there was something bent in the valves, which ended up being the one that had the jacked up spark plug. So now it will soon be time to put it all back together. Can anyone point me towards a good write up, mostly for all the torque specs. Ive done plenty of searching and can't seem to find a detailed write up.
  14. #74 Re: Major Problems-Blown gaskets
    Only thing you really need to worry about torquing down are the head bolts. If you are using head bolts and not head studs the specs are 37 ft/lbs + 130 degrees + 30 degrees up-to-10/98. 37 ft/lbs + 120 degrees 10/98 and later. I would torque down the rocker bolts if you removed them.
  15. #75 Re: Major Problems-Blown gaskets
    May 2012
    Phoenix, AZ
    Quote Originally Posted by slick2500 View Post
    What do you mean by +30 up to 10/98? What are the specs for the rocker bolts?
  16. #76 Re: Major Problems-Blown gaskets
    If you're car is made before 10/98 those are the torque specs 37 ft/lbs plus 130 degrees plus another 30 degrees. After that date the specs are 37ft/lbs plus 120 degrees. You will need a torque angle gauge. If I ever built another 3800 top end I would use head studs instead.
    Depends on what rocker bolts you get, stock rocker and head bolts are not reusable btw, at least I wouldn't reuse old rocker bolts, stocks are torque to yield iirc, and the comp cams are reusable zzp has the torque specs listed for the rockers on their site. The reusable rocker bolts are only like $20.
  17. #77 Re: Major Problems-Blown gaskets
    May 2012
    Phoenix, AZ
    Why head studs?
    I have the comp cam rocker bolts which I know they are reusable. I'll check the site. Thanks.
  18. #78 Re: Major Problems-Blown gaskets
    They are reusable and you just torque them down No need to worry about stupid angles.
  19. #79 Re: Major Problems-Blown gaskets
    May 2012
    Phoenix, AZ
    Where can those be found?
  20. #80 Major Problems-Blown gaskets
    ZZP, intense, prj etc etc I prefer prj's since I stripped the hex style comp cam ones on / separate occasions. Yes they were torqued properly.
    04 Comp G.
  1. 2002 gtp with blown head gaskets??
    By sdstutz in forum Introductions/Noob Questions
    Last Post: 01-30-2013, 11:54 PM
  2. major problems 01 gtx
    By black01gtx in forum Introductions/Noob Questions
    Last Post: 01-15-2013, 09:15 PM
  3. Car. Went through MAJOR problems.
    By 94grandprixNOwhipple in forum General Grand Prix Discussion
    Last Post: 02-22-2012, 10:25 PM
  4. Cars with blown head gaskets
    By GAFF in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-09-2010, 08:43 AM
  5. Major Problems - Need help, please
    By dellfire in forum Off Topic Discussion
    Last Post: 11-04-2009, 09:37 PM
