What you'll need to do:
Check the pinouts on the wiring harness at the fuse box. Likely they aren't super different.
Have your pcm programmed to be an 02 SC'd car with your vin (if you have inspection), and remove the high speed fuel pump codes etc.
Adapt the fuel lines
Use your SC torque converter, or switch over to a 245mm flex plate pattern.
