Thread: engine swap question?
Results 1 to 9 of 9
  1. #1 engine swap question?
    SE Level Member JimSWylie's Avatar
    May 2013
    Newport, WA
    I have a 1998 gtp and am picking up a 2002 grand prix with a blown 3.1 engine and was wandering what all is needed to transfer to the 3.8 sc engine into the 3.1 gp-
    wire harness under the hood, pcm, dic, insrument cluster, anything else im missing?
  2. #2 Re: engine swap question?
    Feb 2013
    37.295091, -121.930053
    Tranny
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: engine swap question?
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    You'll have to wire up the performance shift button as well
  4. #4 Re: engine swap question?
    Feb 2013
    and you will need an aeroforce to monitor kr
  5. #5 Re: engine swap question?
    Nov 2011
    NY
    and you will need to monitor kr
    FIXED... The Aeroforce is not the only way to monitor, lol
  6. #6 Re: engine swap question?
    if your just putting the stock engine in there you dont need a aeroforce gauge. if you plan to mod it, put it on the list of parts you "need".
    and you'll want its exhaust manifolds and the cat back if the GT is a single muffler. maybe take the back bumper if its still good. take the muffler bracket off the pass side of the 98 and put it on the gt, theres a spot for the bolts.
    i just repainted my bumper with duplicolor rattle can, it looks damn good. so if the bumper dont match you can make it match for less then 50 bucks.
  7. #7 Re: engine swap question?
    May 2013
    Newport, WA
    I was wanting to put the 1998 s.c. 3800 into a 2002 Grand Prix SE that has the 3100 with a spun bearing in it.
    The car has only 174,000 miles on it and is in mint condition other than the motor, front bumper cover, and front passenger fender.
    I can get the body parts pretty cheep here. I know the trans will not hold up to the s.c. 3.8 but its just in for this winter to get me a daily driver for work while i rebuild my 4t65e that goes with the s.c. 3.8. I know i will have to leave my lead foot a home and stay out of boost i get all of that. Just looking for a definite answer and a little guidance of what all i will need to change between the two cars to make it all work correctly
    Also the only mod if you want to call it one is a cai
  8. #8 Re: engine swap question?
    SE Level Member GTP313's Avatar
    Nov 2013
    Detroit, MI
    I'm actually doing the same thing next week, picked up a 2000 gt body with no front cradle or wheels or tires for $200 to swap my Gtp engine and tranny into. I would suggest doing a full front cradle swap. It tends to be easier IMO. Plus, I could be wrong, but I think the gtp has different axels and suspension and what not. And also make sure you swap over your fuel pump, gtps have a 2 speed pump with a resistor, otherwise you'll have to tune your PCM for a single stage pump. Good luck on your swap! Hope everything goes good!!
  9. #9 Re: engine swap question?
    What you'll need to do:
    Check the pinouts on the wiring harness at the fuse box. Likely they aren't super different.
    Have your pcm programmed to be an 02 SC'd car with your vin (if you have inspection), and remove the high speed fuel pump codes etc.
    Adapt the fuel lines
    Use your SC torque converter, or switch over to a 245mm flex plate pattern.
  1. Engine Swap Question
    By sevenhellz in forum General Grand Prix Discussion
    Last Post: 12-17-2013, 05:38 AM
  2. question on engine swap
    By beauchamp48 in forum Introductions/Noob Questions
    Last Post: 10-29-2012, 05:48 PM
  3. engine swap question
    By chrisLB in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-09-2012, 09:50 AM
  4. Engine Swap Question
    By Points70 in forum General Tech Discussion
    Last Post: 04-18-2012, 06:45 AM
  5. engine swap question!
    By gagemonster in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-16-2010, 10:52 PM
