Thread: Oil pressure sandwich plate size?
Results 1 to 14 of 14
  1. #1 Oil pressure sandwich plate size?
    GT Level Member m17davis's Avatar
    Orland Park, IL
    Hey guys, I just bought a oil pressure gauge and I was wondering what size adapter I need. I know I need one with the 1/8in port. But what about the fitting?
    Ported Gen III ~ 3.4 ~ HAI ~ 180stat ~ 605's ~ Speed Daddy's ~ SLP Catback ~ A/C delete ~ Aluminum Sub-frame ~ AGX Coilovers ~ Vinnie Spacers ~ Fusebox & PCM Relocation ~ Wire Tuck
  2. #2 Re: Oil pressure sandwich plate size?
    Just screw it into the stock oil pressure gauges spot, the dummy light isnt needed.
    Though I still think you need a reducer to make it screw in.
  3. #3 Re: Oil pressure sandwich plate size?
    Orland Park, IL
    I knew where it was supposed to go.. But I can tell by eye that the fitting on the stock oil sensor is way bigger than the fitting on the electrical sending unit for the gauge. I needed to know what size adapter I need.
  4. #4 Re: Oil pressure sandwich plate size?
    take the stock sensor out and go to the store with it, then match it all up. hardware store may be the place to go if the parts store dont have it.
  5. #5 Re: Oil pressure sandwich plate size?
    3/8 to 1/8 npt fitting
    04 Comp G.
  6. #6 Re: Oil pressure sandwich plate size?
    Orland Park, IL
    do you think its possible to rig somethin up at a ace hardware?
  7. #7 Re: Oil pressure sandwich plate size?
    ace is the place. i plugged my sensor hole with a brass plug. got it from ace. they got all sorts of stuff. tell the counter guy what your doing and they will help you out. they know where all the stuff is and it just flat out goes faster with their help.
    bring the stock sensor and the new one, that way you cant f up at all.
  8. #8 Re: Oil pressure sandwich plate size?
    Orland Park, IL
    sweet. omw there as we speak.
  9. #9 Re: Oil pressure sandwich plate size?
    side note. get some thread sealant, or some Teflon tape to seal the threads.
  10. #10 Re: Oil pressure sandwich plate size?
    Orland Park, IL
    mission complete! thanks guys
  11. #11 Re: Oil pressure sandwich plate size?
    now tuck them wires into some wire loom to keep them from harm.
  12. #12 Re: Oil pressure sandwich plate size?
    Pennsylvania
    So what size was it? Redcompg said 3/8 to 1/8, but the gauge I bought says it'll be 1/4 to 1/8 in the installation sheet online.
    Sport Edition Kv5 18x8
  13. #13 Re: Oil pressure sandwich plate size?
    Orland Park, IL
    it was 1/4. I bought the 3/8 and 1/4 just in case. it was under $6 at ace for both
  14. #14 Re: Oil pressure sandwich plate size?
    Hmm interesting hey at least I was 1/2 right lol
    04 Comp G.
  1. License Plate Bolt Size?
    By mrspindlelegs in forum General Tech Discussion
    Last Post: 03-19-2012, 02:09 PM
  2. My 2004 GTP CompG - 56k get a sandwich
    By stkks in forum Visual/Body Modifications
    Last Post: 05-13-2008, 07:48 AM
  3. What size is the fuel pressure test port?
    By alacran in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-10-2008, 08:27 AM
  4. anyone live around the sandwich area?
    By twistin*6 in forum Midwest
    Last Post: 04-18-2008, 05:03 PM
