Thread: Running Rough after VC Gasket
Results 1 to 13 of 13
  1. #1 Running Rough after VC Gasket
    GTP Level Member WhiteLightningGTP's Avatar
    Nov 2012
    Frankenmuth, MI
    Changed my leaking valve cover gasket on the '99 GTP. Went to start it just a bit ago and it'll barely idle. I killed it after about 10 seconds and double checked everything. I have no clue what the deal is, vacuum lines appear to be in the correct spots, plug wires, etc.
    2004 Comp G "The Panda"- low, e85, big brakes SOLD
    2002 Trans Am- 6 speed, bolt ons or something, it's slow.
    2006 Silverado- forged ls2, 4l80e, plate kit, also slow...
  2. #2 Re: Running Rough after VC Gasket
    Dec 2012
    Where 4T65E's were born
    Did you unplug your injector wires when doing the rear vc?
    Sold.
  3. #3 Re: Running Rough after VC Gasket
    spray some carb cleaner at the vac lines, if the idle jumps up you found the leaking vac line area.
  4. #4 Re: Running Rough after VC Gasket
    Nov 2012
    Frankenmuth, MI
    Yes, I did.
  5. #5 Re: Running Rough after VC Gasket
    Dec 2012
    Alright I was referring to make sure they were plugged back in lol. Check the vacuum lines, sometimes working around them will make any dry rotting turn into cracks that leak. Doing what scotty said will work if it will stay running, it may just kill it since you said it will barely idle.
    Sold.
  6. #6 Re: Running Rough after VC Gasket
    Nov 2012
    Frankenmuth, MI
    Could this be causing it? This is the one at the throttle body.
  7. #7 Re: Running Rough after VC Gasket
    oh the busted evap line. i broke that one too.
    i got a fat line, then jammed a smaller one inside it, then the plastic tube into the smaller vac line.
    like this.
  8. #8 Re: Running Rough after VC Gasket
    SE Level Member sco77's Avatar
    MD
    If you took the coil pack bracket off it could be the ICM ground wire.
    98 GTP - Retired
    86 Fiero GT - L67 | VS Cam | Polished GenV | Headers to 3" Catback to dual/dual Tips | 42.5# | N*
  9. #9 Re: Running Rough after VC Gasket
    Nov 2012
    Frankenmuth, MI
    Plugs are soaking wet. Had it running for a bit longer.
  10. #10 Re: Running Rough after VC Gasket
    Dec 2012
    Did you unplug any sensors? Like Map or Maf?
    Sold.
  11. #11 Re: Running Rough after VC Gasket
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    Icm, wet plugs = no spark. Check coils, icm and icm harness.
    If You Cant Hear The Whine You're Too Far Behind...
  12. #12 Re: Running Rough after VC Gasket
    Nov 2012
    Frankenmuth, MI
    Long story.. But the previous owner had a coil pack replaced by a dealership a couple years back. All the plug wires were mixed up , but it ended up being off just right and running fine. I had the plugs off on the coil side and put then back in correct order via the manual, without thinking that the spark plug side was screwed up.
    I appreciate the help everyone, thanks!
  13. #13 Re: Running Rough after VC Gasket
    Jul 2011
    Baltimore, MD
    mine did that after changing rear plugs. the broken evap plug you showed first was the reason
  1. 05 GTP running rough (sometimes)
    By gwog in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-10-2012, 02:01 PM
  2. running rough
    By BOOSTED GP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-09-2011, 11:58 AM
  3. GTP Running Rough.. few new parts but still not running right.. HELP
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2010, 02:34 PM
  4. 01 GTP running rough
    By tazgtp in forum General Tech Discussion
    Last Post: 03-28-2010, 04:10 PM
  5. GTP Running rough.. PLEASE HELP!!!
    Last Post: 07-11-2009, 08:46 PM
