Thread: GTP AFR Range?
Results 1 to 17 of 17
  1. #1 GTP AFR Range?
    GT Level Member fri3dchick3n's Avatar
    Alaska
    Hey guys. According to my AEM WB I am running 10.4-10.9 AFR at WOT. Ive had trouble finding a GTP AFR range so im asking you guys if this seems normal?
    Mods are: 3.5 MPS, SD Headers, Shift Kit, Intake. Meth but its OFF currently.
    99 GTP: 3.4'' MPS, Overkill PCM, Intake, Catless SD Headers, TransGo Shift Kit, 180º Thermostat, Flipped Dog Bones
  2. #2 Re: GTP AFR Range?
    Last I checked IIRC guys like to keep it at the 11.5 range but I'm sure others will chime in
    04 Comp G.
  3. #3 Re: GTP AFR Range?
    11.4ish is "ideal" for a safe setup. more lean means it'll probably make more power, but be more apt to detonate. more rich and it'll be safer, but you'll lose power.
  4. #4 Re: GTP AFR Range?
    Florida
    Correct for boost most target 11.5. But 11-12 is ok and for NA 11.5-12.5
  5. #5 Re: GTP AFR Range?
    Quote Originally Posted by Z34Phoenix View Post
    Some would argue 11.0 on the street.
    And NA is 12.5-13.5.
    10's is the reality of most canned PCMs.
  6. #6 Re: GTP AFR Range?
    May 2012
    Pittsburgh
    Quote Originally Posted by fri3dchick3n View Post
    10.4 is very rich. 10.9 is rich, but not that far off. I like low 11s AFR for a non-charge cooled roots blower car like yours. With an intercooler, mid-high 11s are OK.
    Also note that you are going to be richer still (generally by .5 AFR, but it depends on nozzle size and water/meth ratio) when the meth is flowing.
    I'd take a good look at your fueling and make some changes. I don't like that your AFR fluctuates by .5 at WOT (that's way too much) and wonder if you have a mechanical fuel delivery issue (dirty filter, weak pump) or a tune issue (MAF not dialed in). Is it getting richer or leaner during a pull? Once you get AFR to not fluctuate so much I'd lean it out to the low 11 range.
    Active Roster: 2006 Grand Prix GT - Supercharged/Intercooled 2005 Mustang GT - 2012 Impala LT
    Injured Reserve: 2000 Regal GS - 1993 Mustang LX
  7. #7 Re: GTP AFR Range?
    Alaska
    At WOT it slowly works it way up to the lean side. I believe I might have a small exhaust leak at my Flex Pipe area.
    Going to clean up coils and replace plugs here in a little bit.
    Going to do some logs with a local friend who has HPTuner and send them towards DynoBrian at Mobiledyno.
    Nobody localy knows how to tune a GTP with meth -.-
  8. #8 Re: GTP AFR Range?
    sounds like a fueling problem in the tune, like the power enrichment isn't setup properly.
    and realistically. tune without the meth first, then turn it on and see where you can add timing and boost. i'd personally leave the timing alone and run more boost.
  9. #9 Re: GTP AFR Range?
    Alaska
    Damn, I was planning on running a 3.5 and whatever timing I can get. I do have a 3.4 in garage though, That is the only way to change our boost is to swap pulleys right?
    My car ran great, decided to get meth, Got a local retune, Was complete garbage, had him return back to the tune I had before, and now its running like this.
    Had the local tuner send the file to Brian at Mobiledyno and he compared them and they are the same. So Im in a pickle.
  10. #10 Re: GTP AFR Range?
    yeah, pulley swap for more of less boost.
    you can do whatever you'd like with your car, but i prefer the more boost method to more timing method on my cars. if you want timing then go for it.
  11. #11 Re: GTP AFR Range?
    Alaska
    Ive just understood that you will benefit off more timing than boost for us. But I think I heard its more stress on the engine itself, is that true?
  12. #12 Re: GTP AFR Range?
    a lot of timing and you'll blow the head gaskets, but it's pretty uncommon. more timing just leaves you more prone to detonation when under heavy load.
  13. #13 Re: GTP AFR Range?
    Alaska
    I see, I'll just stick with the 3.5, my car seems to like it better I guess. Thanks for you input.
  14. #14 Re: GTP AFR Range?
    The Boss Iceman6669's Avatar
    Jun 2011
    Exactly how much timing is A LOT? I have heard of guys running 28* long term...
    2011 F-150 Yote powered
  15. #15 Re: GTP AFR Range?
    Quote Originally Posted by Iceman6669 View Post
    most likely not an issue with him because i bet he runs MLS gaskets, right?
    if you blow a metal gasket then something went wrong.
  16. #16 Re: GTP AFR Range?
    Jun 2011
    No actually he was running FelPros... He said that way the head gaskets would go before the motor got hurt..
  17. #17 Re: GTP AFR Range?
    I run 10.8 to 11, I like moar fuel.
    Stock PE is near 11 anyway, on a wideband.
  1. What do low range mean???
    By Pierre in forum General Tech Discussion
    Last Post: 04-02-2013, 10:43 AM
  2. New sub box...where'd my range go?
    By Sven the Sexman in forum Audio, Security & Visual Electronics
    Last Post: 09-02-2012, 07:11 PM
  3. Trip to the range
    By IR II IP IDEATH in forum Off Topic Discussion
    Last Post: 02-27-2011, 05:10 PM
  4. mid range struggle
    By venge24 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2011, 03:43 PM
  5. Bad MAP??? What should the range be?
    By l67fiero in forum PCM Tuning
    Last Post: 08-14-2009, 01:54 PM
