Thread: GTP Running rough.. PLEASE HELP!!!
Results 1 to 5 of 5
  1. #1 GTP Running rough.. PLEASE HELP!!!
    SE Level Member azmattaz06's Avatar
    Feb 2009
    Tucson
    Ok so my 98 GTP has been taking a while to start meaning you have to crack it a few times before it starts.. well recently my car started stuttering every time i give it gas, so i bought a fuel pump installed it and that completely fixed my starting problem but the stuttering is still there when i give it gas.. Also about a month ago i put in spark plugs so i know it's not that.. What next? it's very annoying when u wanna kick the crap outta some honda but cant because it's running like crap.. Im thinking wires next? i've had the same problem in other cars and usually the plugs fixed it but these are new so??? any ideas? thanks guys
  2. #2 Re: GTP Running rough.. PLEASE HELP!!!
    Plug wires? If not coil packs or ICM (piece the coils sit on)...but most of the time it is wires or coils. Try those...btw is it a flashing ses light when it misses?
  3. #3 Re: GTP Running rough.. PLEASE HELP!!!
    GT Level Member popeyenate's Avatar
    Jan 2009
    san diego
    you bend one of the wires a little too much when putting on the new plugs? that could cause some exciting stuff while driving. it could be time for wires too
  4. #4 Re: GTP Running rough.. PLEASE HELP!!!
    SE Level Member lageR's Avatar
    Jan 2009
    IL
    Sounds MAF related to me. Unplug the MAF sensor (the sensor on the front-top of the throttle body) and see if it runs any better. If it does, the MAF needs either cleaned or replaced.
  5. #5 Re: GTP Running rough.. PLEASE HELP!!!
    GT Level Member DOUGLASMELTER's Avatar
    Apr 2009
    ERIE
    pull the plugs again and check them and the coils. do u have a multimeter?
  1. rough shifting
    By grandprix85 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-08-2009, 11:52 AM
  2. Rough Start
    By Willthesage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-16-2009, 11:56 AM
  3. '97 GTP, rough idle
    By oldschoolpontiacs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2009, 01:14 AM
  4. Almost rough idle
    By DesQ27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-01-2009, 08:31 PM
  5. Help Car running rough SES light MAF dead
    By RNUOVR in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2008, 07:25 PM
