Thread: Running pig rich and stalls when warm
Page 1 of 3 123 LastLast
Results 1 to 20 of 54
  1. #1 Running pig rich and stalls when warm
    Aug 2013
    Kitimat, B.C.
    I'm talking diesel rich, the pipes are black and you can visually see it rolling out the pipe with every spike of the throttle. I have seen my fuel trims at -17. Once it's warm it surges and wants to stall. I have replaced the o2, iac, maf and map sensors. I noticed a small header leak at cylinder #2 because the header wrap was getting sooty. It wasn't something that I could feel but I welded it up. The spark plugsan o2 were sooty. MThe idle seems normal. I doubt I have a vacuum leak as its all new hoses. I did spray the engine with carb cleaner ad seafoamed it and didn't turn up anything.
    86 Fiero se convertible 3800sc 4t65e HD(2002), Gen V, 3.3 pulley, SD headers
  2. #2 Re: Running pig rich and stalls when warm
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    vacuum leak would have you run lean,
    fix your map
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  3. #3 Re: Running pig rich and stalls when warm
    Aug 2013
    Kitimat, B.C.
    Quote Originally Posted by Seachicken View Post
    fix your map
    It was running rich before, thats why I changed out all sensors. The maf was because it set a code. For the map, I have one in there now I just need what the operating perimeters are to see if it's correct.
  4. #4 Re: Running pig rich and stalls when warm
    Mar 2013
    Colorado - USA
    Pull and label all six spark plugs to see if they are burning evenly. Any single plug that seems to be burning especially cleanly would indicate a lean condition which could stem from a bad injector, air leak, electrical problem, etc. A plug showing a color that is darker t han KFC Fried Chic ken could indicate an injector that is running colder or more richly..
    E85 L32 S1X Heads 105#Crow Springs LQ4 2k+NStarTB Deka 60# Gen1 SLP Headers Stock Plugs
    19 deg GFS and ZERO KR@14 PSI <10% LTFT
    GMPP Struts/Springs SLP Sway Bars Z06 Brakes
  5. #5 Re: Running pig rich and stalls when warm
    Aug 2013
    Kitimat, B.C.
    I finally had a few mins, literally few mins. The ect and air both show 15 the map shows 230 with KOEO.
  6. #6 Re: Running pig rich and stalls when warm
    Aug 2013
    Kitimat, B.C.
    for those of you that have hptuners heres a log of it warm and surging as well as it running rich.
    http://www.hptuners.com/forum/showth...rges-when-warm
    had to add a link as i couldn't upload the file.
  7. #7 Re: Running pig rich and stalls when warm
    Aug 2013
    Kitimat, B.C.
    Quote Originally Posted by Shmoke View Post
    All are blacker than Toby's a$$
  8. #8 Re: Running pig rich and stalls when warm
    Aug 2013
    Kitimat, B.C.
    I went out and really doused the upper manifold gasket with two cans of carb cleaner and I seem to have a leak in the manifold next to the thermostat so I have a new gasket ordered and will be in on Wednesday. Anything I should take care of easily as I have the blower off?
  9. #9 Re: Running pig rich and stalls when warm
    Dec 2010
    DMV
    You could paint and make the bay sexy.
    Sent from my HTC One using Tapatalk
  10. #10 Re: Running pig rich and stalls when warm
    new vac lines and vac tee's they are gonna break, should have them before you do the work, its 5 bucks worth of piece of mind.
  11. #11 Re: Running pig rich and stalls when warm
    Aug 2013
    Kitimat, B.C.
    Those broke on the tear down before the install, already replaced. Good call though.
  12. #12 Re: Running pig rich and stalls when warm
    Aug 2013
    Kitimat, B.C.
    We'll I have the new gasket on and it's still leaking from the same area in the upper plenum around the thermostat housing. Now what?
  13. #13 Re: Running pig rich and stalls when warm
    Aug 2013
    Kitimat, B.C.
    Anyone?
  14. #14 Re: Running pig rich and stalls when warm
    your sure everything is clean and free of old gasket?
    you can try a thin smear of rtv both sides of the gasket around the outer edge of the gasket. torque it back down let it sit over night to cure, then fire it up.
  15. #15 Re: Running pig rich and stalls when warm
    Aug 2013
    Kitimat, B.C.
    I reseated the intake gasket and I think I got it but I'm still running rich and surging when warm. I made a contraption to pressurize the intake through the throttle body and I was leaking from the map so I took it out and siliconed it and that helped, now it leaked down from 20 or so psi very slowly, I soaped the engine and I didn't' see any. Mabey the purge solenoid? I'm thinking of taking off the throttle body and making a block off plate and then pressurize it from the octopus. I'm just wondering if if possibly be leaking from the brake boost port? I'll have to make a smoke test and see if that shows something
  16. #16 Re: Running pig rich and stalls when warm
    GT Level Member primem's Avatar
    Sep 2013
    Calgary, Alberta
    Quote Originally Posted by tweeder View Post
    cigar and section of hose...the scotty kilmer smoke machine.lol
    2004 comp g
  17. #17 Re: Running pig rich and stalls when warm
    Florida
    negative fuel trims means it is pulling fuel. i would check that you don't have a stuck injector or bad fuel psi reg. test fuel pressure might be too high.
  18. #18 Re: Running pig rich and stalls when warm
    Aug 2013
    Kitimat, B.C.
    Quote Originally Posted by Z34Phoenix View Post
    Sorry negative fuel trims mean it's running rich. I have a fuel pressure guage on the rail and it's reading around 43 psi.
  19. #19 Re: Running pig rich and stalls when warm
    Aug 2013
    Kitimat, B.C.
    Not sure if this is it but I sprayed a soapy solution in the injector holes and sure enough injector number three is bubblin, so I have a set of o rings on order.
  20. #20 Re: Running pig rich and stalls when warm
    Aug 2013
    Kitimat, B.C.
    Got the new o rings in and now a new problem, I swear I get a new problem every time in fix something else. Now it won't start, I checked and I am getting fuel and spark but it backfires really powerful and loud. So powerful that it blows the rubber exhaust tubing right off the pipes.
  1. Running too rich?
    By 94GrandPrixSE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-18-2013, 09:43 AM
  2. Stalls when warm and mis-fires at 4000 RPM
    By jrowell in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-15-2012, 10:56 PM
  3. Car is running rich... I think
    By ElAlacran2010 in forum General Tech Discussion
    Last Post: 02-25-2011, 08:51 AM
  4. Running rich
    By saleenprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2010, 08:53 AM
  5. 1998 Gd Prix sputters and stalls when engine warm
    By jmickevi in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-18-2010, 02:05 AM
