Thread: Running too rich?
Results 1 to 6 of 6
  1. #1 Running too rich?
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    My check engine light came on during my drive to work so I plugged in my Bluetooth scanner on my way and got a P0172 (System Too Rich Bank 1)
    OBD-II Trouble Code: P0172 System Too Rich (Bank 1)
    My fuel trims are all out of wack im getting -12.5 to -19.5 LTFT and +10 to -10 STFT. I cleaned my MAF and check vac lines. I thought mabye the
    180 stat was causing it but I replaced it with my 195 with almost no difference in fuel trims and its still happening. I searched for someone having
    a similar problem but almost nothing came up for the code on GP's. Car details in sig. Im stumped here guys. Any ideas?
    02 GTP - Cartuning Turbo Kit VS67 3" DP, 80#INJ, N*,LQ4 MAF, Custom Cam, Roller Rockers, 130#, P&P Heads, Meth, AL103's, Corn fed, 522WHP on a mustang dyno, HP Tuners by me.
  2. #2 Re: Running too rich?
    SE Level Member A2tripp's Avatar
    Jun 2013
    Upstate ny
    Did you use a guage when you checked your vacuum?
    exhaust leaks can also fool the PCM making it think the motor is running lean
    99 gtp
    04 powerstroke
  3. #3 Re: Running too rich?
    Nebraska
    yeah scanner and my gauge pod to monitor vac everything is normal 20 in Hg idle and 8psi of boost. Could bad gas cause the car to run rich? if there was water in it you would think it would be running lean and adding fuel to compensate not cutting fuel?
  4. #4 Re: Running too rich?
    Nebraska
    Got different gas still getting bad LTFT's Short trims look better getting 7 to -7 STFT's. I should also mention that I have no misfires.
  5. #5 Re: Running too rich?
    Aug 2012
    michigan
    I have the same problem with my 00 GTP. Getting the same code and have posted about it here...
    http://www.grandprixforums.net/2000-...ich-82499.html
  6. #6 Re: Running too rich?
    Nebraska
    Im still struggling with this, Im thinking about replacing bank 1 o2 sensor. Sensor seems to be working fine but im out of ideas. Overkill pcm will be here today and I have the bank 2 (after cat o2) deleted I will update if I figure anything out.
  1. Running rich at times then lean?
    By MustangKiller92 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-23-2013, 11:16 AM
  2. 500 RPM idle, running rich, missfire...
    By deadsnake in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2013, 07:40 PM
  3. Car is running rich... I think
    By ElAlacran2010 in forum General Tech Discussion
    Last Post: 02-25-2011, 08:51 AM
  4. Running rich
    By saleenprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2010, 08:53 AM
  5. car running really rich
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2009, 04:48 PM
