Thread: help! 2000 gtp stalls randomly then starts up 5 minutes later!
Results 1 to 20 of 30
  1. #1 help! 2000 gtp stalls randomly then starts up 5 minutes later!
    Mar 2012
    Hoffman Estates
    hey guys kinda new here been trying to diagnose my grand prix but im havig some problems! it all started a couple months ago when my car died randomly in my parking lot but started up the next day. after that no problems for a couple weeks until it started to stall out on me on my morning drives to work. it would stall out no sputters or anything just dead. it would start up the 3rd or 4th try. I started to do this more nd more so I left it at my parents house for a month or so so my dad could get it looked at. needless to say he takes it into his shop the tech runs it on the scanner for 2 hours and nothing happens. he continues to drive it for 3 weeks and no problems at all! no I get my car back and it dies not even a mile from my parents house I trun it over nothing I try 5 times then it turns over finally! I was fed up. so I changed my fuel filter which was nasty btw clean my air filter, throttle body, IAC and replaced the fuel pressure regulator. after all that she died on me the next day. I have now bent the tab on my #15 relay for the low to high speed fuel pump. what can I do next ?! 2000 Pontiac grand prix gtp 231,000 miles ! hope you guys can help!!
  2. #2 Re: help! 2000 gtp stalls randomly then starts up 5 minutes later!
    Mar 2012
    Hoffman Estates
    I honestly don't know what to do next but to buy the fuel pump resistor relocation kit and see if that will do the trick !?
  3. #3 Re: help! 2000 gtp stalls randomly then starts up 5 minutes later!
    GTX Level Member Bills1997GTP's Avatar
    Oct 2012
    Philadelphia
    Do any lights light up on the dash before this happens? Or is it just a random thing
  4. #4 Re: help! 2000 gtp stalls randomly then starts up 5 minutes later!
    Mar 2012
    Hoffman Estates
    Its a random thing no cels or anything but as of yesterday I have p171 I think bad o2 clogged injector or fouled plugs. I'm leaning towards the fouled plugs considering how bad my fuel filter was.
  5. #5 Re: help! 2000 gtp stalls randomly then starts up 5 minutes later!
    your crank sensor is taking a crap on you, time to change it.
    if you noticed the tach dropping to zero before it stalls, its the crank sensor for sure. this sensor rarely sets a code for its self. it causes random stalling as you drive down the road. will fire right back up, or not, or next week lol just like your saying its done.
    http://www.grandprixforums.net/how-r...sor-60906.html
  6. #6 Re: help! 2000 gtp stalls randomly then starts up 5 minutes later!
    Mar 2012
    Hoffman Estates
    Is there a way to make sure its the cps?
  7. #7 Re: help! 2000 gtp stalls randomly then starts up 5 minutes later!
    Feb 2013
    37.295091, -121.930053
    ^^ this scotty told you what to look for gesss freaking read sometime
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  8. #8 Re: help! 2000 gtp stalls randomly then starts up 5 minutes later!
    Mar 2012
    Hoffman Estates
    Is there anyothet way? Or is it just hope I see it drop before it cuts out on me?
  9. #9 Re: help! 2000 gtp stalls randomly then starts up 5 minutes later!
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    It sounds like your CPS its easy as long you have the correct puller
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  10. #10 Re: help! 2000 gtp stalls randomly then starts up 5 minutes later!
    id have to say if you searched the forum here far and wide, every post that says, my car stalls out while driving, no warning at all, i noticed the tach drops to zero before it stalls, some times it starts right back up, other times it needs a tow truck. then will start when its back home 4 hours later......it was the crank sensor gone bad.
  11. #11 Re: help! 2000 gtp stalls randomly then starts up 5 minutes later!
    GT Level Member kjclawson's Avatar
    Fort Myers, Florida
    Had a similar problem just last week. I replaced a few other things and it turns out it was the crank sensor...
  12. #12 Re: help! 2000 gtp stalls randomly then starts up 5 minutes later!
    Mar 2012
    Hoffman Estates
    can i complete this job without having the "HB/steering wheel puller"? i only have hand tools no fancy pullers or anything!! :/ i was going to attempt to do this tomorrow morning..
  13. #13 Re: help! 2000 gtp stalls randomly then starts up 5 minutes later!
    you need a puller, like this one, and the right bolts, they are listed in that how to thread.
    you can rent this type of puller for free at az or pep boys. but will have to buy the bolts you need from a hardware store.
  14. #14 Re: help! 2000 gtp stalls randomly then starts up 5 minutes later!
    Feb 2013
    not busting your balls scotty but that engine looks backwards like the starter is wrong.
  15. #15 Re: help! 2000 gtp stalls randomly then starts up 5 minutes later!
    Feb 2013
    but yeah that is the right tool for that. other than the starter beening in the wrong location. what car has the starter next to the harmonic balancer? I would like to slap that engineer
  16. #16 Re: help! 2000 gtp stalls randomly then starts up 5 minutes later!
    i dont have a clue what engine that is lol (stole it off the net) but like stated, its the puller you want to use, and no other.
  17. #17 Re: help! 2000 gtp stalls randomly then starts up 5 minutes later!
    Feb 2013
    thats why i said im not busting your balls lol i figured you got it off the net
  18. #18 Re: help! 2000 gtp stalls randomly then starts up 5 minutes later!
    i hear ya, i thought id comment.... that engine looks like its air cooled like VW engine.
  19. #19 Re: help! 2000 gtp stalls randomly then starts up 5 minutes later!
    Aug 2013
    Canton Ma
    I. New to pontiac a. But I had the exact same symptoms in my thunderbird supercoupe. Drove me nuts.
    Changed it out havnt a stalling in 5 months. It's the crank sensor.
  20. #20 Re: help! 2000 gtp stalls randomly then starts up 5 minutes later!
    Mar 2012
    Hoffman Estates
    How the **** do I get the crankbolt off?! I can't figure it out! Nothing will hold the pulley in place!!
  1. Starts, runs fine for a week, then won't start for 5 minutes, then starts and runs...
    By Summit670 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-26-2012, 05:33 PM
  2. 2001 Grand Prix GT starts then stalls then starts up and is fine???
    By 81X11 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-06-2012, 10:29 PM
  3. 2000 GTP starts but stalls please read!!
    By mikedinthecity in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2010, 08:33 AM
  4. 1991 grand prix starts then dies after five minutes
    By oithebusiness in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-15-2009, 12:54 AM
  5. Runs 5 minutes...Stalls...Changed everything
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-09-2009, 02:47 PM
