Thread: help! 2000 gtp stalls randomly then starts up 5 minutes later!
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21 Re: help! 2000 gtp stalls randomly then starts up 5 minutes later!
    GTP Level Member Twizted 1's Avatar
    Jul 2013
    Summertown Tn
    1/2"impact. That's what I've always used.
  2. #22 Re: help! 2000 gtp stalls randomly then starts up 5 minutes later!
    Hand tools method:
    Loosen lug nuts
    Jack and support the passenger side of the car.
    Remove the tension from the belt(s) and let them sit there.
    Remove the passengerside wheel (stock is 19mm)
    Remove the plastic splash shield that keeps you from seeing the harmonic balancer. (trim pop tool and sometimes phillips screwdriver)
    Remove the flexplate inspection cover.
    Hold flex with a pair of vice grips
    With a 24mm socket, remove the harmonic balancer bolt.
    Using an HB/steering wheel puller find the correct pieces to pull the balancer because the bolt hole area can be quite long. It requires the short rod and pulling piece in my kit. Along with three bolts M6 x 1.00 and 70-75mm in length. Check that you have these bolts before trying this procedure. 1/4 by 20 bolts will work in a pinch.
    Pull the balancer off and set it aside
    then theres the red neck way. not a grand prix but its the same deal.
    <span style="color: rgb(51, 51, 51); background-color: rgb(250, 250, 250);">
  3. #23 Re: help! 2000 gtp stalls randomly then starts up 5 minutes later!
    SE Level Member JerzNick's Avatar
    Oct 2012
    New Jersey
    You will 100% want an impact, it's much easier to put it back on that way...
    Bored block, Eagle Crank, XP Cam, Ported Heads/LIM/Blower/TB, 3.0 Pulley, CAI, Headers, 42.5#, AL 104's, etc...
  4. #24 Re: help! 2000 gtp stalls randomly then starts up 5 minutes later!
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    Redneck that thing off!
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  5. #25 Re: help! 2000 gtp stalls randomly then starts up 5 minutes later!
    Mar 2012
    Hoffman Estates
    Do both the belts need to come off?
  6. #26 Re: help! 2000 gtp stalls randomly then starts up 5 minutes later!
    Yes.
  7. #27 Re: help! 2000 gtp stalls randomly then starts up 5 minutes later!
    Mar 2012
    Hoffman Estates
    Mmkay both belts off. Crank bolt removed. Now how do I get tge pulley off? I've been beating it and trying to pry it no luc!
  8. #28 Re: help! 2000 gtp stalls randomly then starts up 5 minutes later!
    are you fuking kidding me? go read the god damn how to i posted, and quoted from, my god man!!!!!!
  9. #29 Re: help! 2000 gtp stalls randomly then starts up 5 minutes later!
    Mar 2012
    Hoffman Estates
    I used the puller snd specified bolts. The middle bilt on the puller has a little. Boot on it ,I put that on and it pushed in to crank bolt hole is that supposed to happen? I've been using the puller but it only seems to push the metal boot back in the hole more...is that correct? I know this is quite a hassel I can only imagine how frustrating it is reading. My description s of problems
  10. #30 Re: help! 2000 gtp stalls randomly then starts up 5 minutes later!
    Mar 2012
    Hoffman Estates
    I got it! Everything seems to brle running much better hopefully it stays the same
  1. Starts, runs fine for a week, then won't start for 5 minutes, then starts and runs...
    By Summit670 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-26-2012, 05:33 PM
  2. 2001 Grand Prix GT starts then stalls then starts up and is fine???
    By 81X11 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-06-2012, 10:29 PM
  3. 2000 GTP starts but stalls please read!!
    By mikedinthecity in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2010, 08:33 AM
  4. 1991 grand prix starts then dies after five minutes
    By oithebusiness in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-15-2009, 12:54 AM
  5. Runs 5 minutes...Stalls...Changed everything
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-09-2009, 02:47 PM
