FIXED!! READ ON!!
First off, I originally had a thread that said...Troubleshooting HELP!!! Fuel issue...possible fuel pump????HELP, but to simplify things here goes and thanks for all the previous help.
I have changed the fuel filter, fuel pump, fuel pump relay, fuel pump regulator, EGR, IAC and the spark plugs...and my car will start up fine. After a few minutes it will just sputter and then just shuts off. I can pump the gas a try to keep it running...to no avail. What should I check next? I have already lost all my patience.
Also, the TCS light does not come on, theres no problem with tach, it does not have a resistor (its a GT) and the CPS was new when the motor was installed in December.
Please help...I was thinking MAF, but I don't need to spend anymore on a guess. $700.00 and counting with no fix![]()
