Thread: LIM Gasket
Results 21 to 40 of 48
  1. #21 Re: LIM Gasket
    Jesus degrease that bay!
    04 Comp G.
  2. #22 Re: LIM Gasket
    Quote Originally Posted by Bills1997GTP View Post
    I can't get this injector off
    pull it straight up. twist it a few times that may loosen it up some. certainly looks like its oiled up enough.
    id change the valve cover gaskets while you got it apart.
  3. #23 Re: LIM Gasket
    GTX Level Member Bills1997GTP's Avatar
    Oct 2012
    Philadelphia
    Lol working on it, What's the best stuff to use to clean up this mess ?
  4. #24 Re: LIM Gasket
    Oct 2012
    Philadelphia
    Yea I plan on doing that because its leaking all over my headers
  5. #25 Re: LIM Gasket
    ive used a lot of the parts store sold cleaners, engine foamy brite works good, but i found that crc engine degreaser works just as well if not better with out the smell afterwards.
    what ever you get, buy 2 cans, you'll need it. put the car on ramps, spray underneath first, get the tranny from the pass side wheel well, and from in between the engine and tranny, oil pan , up the sides of the block to the headers. you get the picture. lol
    then spray the top side down. get a old paint brush to scrub any thick areas.
    i say buy 2 cans, because 1 is never enough. sucks when you run out. it goes fast.
    as far as hosing it off, hose everything. the only thing to cover or remove is a open cone filter if you have one. take it off, then use a bag and a rubber band to cover the TB opening.
  6. #26 Re: LIM Gasket
    Oct 2012
    Philadelphia
    Speaking of TB whats the best stuff to clean a dirty TB because mine is dirty as all hell, it's seriously nasty in there... And also I was thinking of painting it red, just for kicks, is there a certain way to do this or no?
  7. #27 Re: LIM Gasket
    04 Comp G.
  8. #28 Re: LIM Gasket
    Just like any other part. Make sure to clean it as best as you could, tape up where you don't want paint to go. Primer, then paint with something like engine enamel.
    04 Comp G.
  9. #29 Re: LIM Gasket
    not sure what year you got there, but if the maf is in the TB take it out, then use throttle body cleaner, or carb cleaner will work.
    dont spray the maf with anything but maf cleaner.
    for paint use a high heat paint, like caliper paint.
  10. #30 Re: LIM Gasket
    Oct 2012
    Philadelphia
    scott Its an 2004 Pontiac Grand Prix.
    And I'm gonna save some fun for tomorrow I think I did a good job so far today ripping this thing apart it's not easy for a rookie like myself lol tomorrow's about cleaning the **** out of it and praying I can put this thing back together lol
  11. #31 Re: LIM Gasket
    just clean the v/c's up when they are off. (inside and out) dry them off, then let them sit in the sun to dry up.
    after its back together and running, then de grease the engine and tranny and walls of your engine bay. you dont want water to get inside the engine.
    you can also spray the rad and condenser with de greaser, then hose it off from the inside towards the bumper, lots of bugs and dirt get stuck in the fins over the years.
    04 your maf is in the tube, no need to remove any sensors to clean the TB.
  12. #32 Re: LIM Gasket
    St. Louis
    The rad was leaking so I bought a new one today along with a new condenser, I'm still gonna flush it tho, this gunk is everywhere
    I wonder if there is a way you can flush the system without the new rad in place? I'd hate to have a brand new clean radiator and then cram it full of the old sludge on startup, ya know?
  13. #33 Re: LIM Gasket
    put the garden hose on full in the lower hose, take the t stat out, take the upper hose off the rad, start the car, do this till clear clean water comes, out, and then a little longer.
  14. #34 Re: LIM Gasket
    Oct 2012
    Philadelphia
    Questionnn I kinda knocked some dirt in the intake by accident and its in a spot that I can't get with a rag ... Am I toast or what?
  15. #35 Re: LIM Gasket
    Vacuum or just spray it with brake cleaner.
    Or just wash it out with a hose, the intake is off the car so it doesnt matter.
  16. #36 Re: LIM Gasket
    Oct 2012
    Philadelphia
    Sorry ment engine where intake goes
  17. #37 Re: LIM Gasket
    i used a screw driver to scoop crap up. a vacuum cant hurt either.
  18. #38 Re: LIM Gasket
    St. Louis
    Worst case make a small nozzle attachment for your vac using some rubber hose. Just duct tape the heck out of one end to the shop vac and go at it. As long as you don't drop anything else down the intake or exhaust runners in the motor (like a bolt, lol...) then you're fine.
    Might be a good idea to take rags and gently stuff them into all the intake and exhaust ports on the block just to avoid any unwanted junk getting in there. Also be sure to clean out the valley before you re-install the LIM.
  19. #39 Re: LIM Gasket
    Oct 2012
    Philadelphia
    Ok I've Been completed this Job but I've had one problem since then, this vac leak, it doesn't seem to effect the idle or drive in any way but the problem is that I can't pinpoint it. it's somewhere below the throttle body near the bottom of the intake and it's not the air box or related as far as I know, and since the cars been down because of a broken rack body I've decided to mess around with it a bit. So far I've come up with nothing and in addition to my troubles also as soon as I started the car I got smoke from the engine.. Closer inspection shows a wet section of the front of my engine by the headers, hopefully that's the valve cover that I never took care of but I'm not too sure, I just hope it's nothing that would lead me to take apart the intake again..
    Watch the video and tell me what you think
    2004 Grand Prix GTP 150,000 " The New Edition "
  20. #40 Re: LIM Gasket
    your link was dead, so i reposted it for ya.
    http://i294.photobucket.com/albums/m...ps4130dc81.mp4
    all i hear is air being sucked into the TB. and it looks to be running smoothly.
    hows it running? it feel ok, or you you get a code to pop up?
  1. LIM gasket or Head Gasket?
    By Fahrenheit in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2013, 06:12 AM
  2. intake manifold gasket or head gasket
    By Eric Whitter in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-17-2012, 01:55 AM
  3. Help is it head gasket water pump or intake gasket
    By jared71 in forum Introductions/Noob Questions
    Last Post: 02-14-2012, 01:26 PM
  4. LIM Gasket, Head Gasket, or bad sensor?
    By GTFiske in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2010, 08:40 PM
  5. gasket kit
    By Andrew_99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2009, 04:39 PM
