Thread: NEED HELP: Codes popped P1125, P2120, P2125, P2138, P0401, P0068 and P0101
Results 1 to 11 of 11
  1. #1 Re: NEED HELP: Codes popped P1125, P2120, P2125, P2138, P0401, P0068 and P0101
    This code is one of the best examples of why you should find information before shotgunning parts. I watched a guy shotgun $320 of EGR's (2 of them) when a forum told him "that's an egr code, you need another". I saw the ongoing issue, googled it and came up with the GM FSM stuff off GearChatter.com Said in the diagnostic aids to check map, becaue the map reads the difference in the air. When the EGR opens, the pressure is expected to change via a map reading. PCM doesn't see it..code is set. Although it has EGR in it's title..it's hardly ever an EGR.
  2. #2 Re: NEED HELP: Codes popped P1125, P2120, P2125, P2138, P0401, P0068 and P0101
    Nov 2011
    DC
    I hear you bro. I took it to two or three different garages and all suggested that I replace the EGR and checked to make sure the tube wasnt blocked. Was about to take it to the dealership. Luckily the EGR only cost me about $65 or so on ebay. My buddy works as mobile mechanic and found the problem w/ an hour of tinkering unlike the brick and mortar shops.
  1. P0332 popped up on the way home
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-06-2012, 08:34 AM
  2. P2138 P1125 codes
    By jlusleton in forum General Tech Discussion
    Last Post: 09-23-2011, 05:35 PM
  3. 99 GTP Popped Codes, and questions for a newbie.
    By Fricker in forum General Tech Discussion
    Last Post: 09-23-2010, 05:17 PM
  4. P0101 and p0172 Codes??
    By Whitehispanic in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-13-2010, 11:55 AM
  5. Runs bad, won't start...Codes P0401 & P0452
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-03-2008, 06:55 PM
