Thread: Can any1 tell me what this noise is?
Results 1 to 19 of 19
  1. #1 Can any1 tell me what this noise is?
    GT Level Member titanfan12's Avatar
    Jan 2013
    west palm
    its a weird noise like scraping or rattleing and it comes and goes. and dont know what it is, or could be. maybe a ac compressor but i used a tethescope and it sounded good.
    Heres the video(dont mind the fireworks at the end). RATTLE NOISE - YouTube
  2. #2 Re: Can any1 tell me what this noise is?
    Does it change with the AC on or off???
  3. #3 Re: Can any1 tell me what this noise is?
    Jan 2013
    west palm
    it doesnt i thought the same thing, but it didnt make a difference with it on or off, but it could be
  4. #4 Re: Can any1 tell me what this noise is?
    Time to spray some WD40 on all the pulleys and see if anything changes.
  5. #5 Re: Can any1 tell me what this noise is?
    Jul 2013
    Lockeport Nova Scotia Canada
    sounds like the clutch of the AC compressor
  6. #6 Re: Can any1 tell me what this noise is?
    Jan 2013
    west palm
    thanks man ill do it first thing in the morning and let you know what goes on.
    its 11 here and im trying to get back on track for regular sleep lol.
  7. #7 Re: Can any1 tell me what this noise is?
    Dec 2012
    Where 4T65E's were born
    Oh, those are fireworks at 0:08 lol. Yeah stick your head in there and start manipulating things to see if the noise changes if you cannot find it right away. It does sound like an AC compressor, but if it's that bad, it must have been making noise for some time.
    Sold.
  8. #8 Re: Can any1 tell me what this noise is?
    Jan 2013
    west palm
    it has been makeing noise for some time but it comes and goes often. And i bet you were like wtf! his engine on fire at 0:08 lol
  9. #9 Re: Can any1 tell me what this noise is?
    Dec 2012
    Nah that's all I've been hearing for the past few days are fireworks, I'm used to it. My compressor started making noise right after I bought my car, and it would come and go, I thought it depended on where the compressor left off. I'd hit the AC button, it would go away, and when it cycles, it would be louder sometimes. I literally just put some of the synthetic motor oil I use in my engine on the ac compressor, and the noise stopped and it's been perfect for months. I put it in the small space between the clutch on the end, and the pulley.
    Sold.
  10. #10 Re: Can any1 tell me what this noise is?
    SE Level Member JerzNick's Avatar
    Oct 2012
    New Jersey
    Have you changed the engine or trans? Someone else posted a noise like that a while ago on here, turned out to be the bolts on the torque converter backed out.
    Bored block, Eagle Crank, XP Cam, Ported Heads/LIM/Blower/TB, 3.0 Pulley, CAI, Headers, 42.5#, AL 104's, etc...
  11. #11 Re: Can any1 tell me what this noise is?
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    Try running the car with the belt off.
    Just to see if it is actually the pulleys
  12. #12 Re: Can any1 tell me what this noise is?
    SE Level Member Jcinstalls's Avatar
    Feb 2013
    Missoula, MT
    I had the exact same noise. Its the clutch on the ac compressor as previously said. I took it off and cleaned the clutch but what fixed it was bending it back to the un engaged position. I think overtime/heat made it half engaged and touch the pulley and cause that exact noise. Good luck.
  13. #13 Re: Can any1 tell me what this noise is?
    GT Level Member Deviq's Avatar
    SE WI
    What did you bend back exactly? Mine started doing the same thing a few days ago was wondering if it was shot or could be re-oiled/fixed somehow.
    Quote Originally Posted by zildjian102
    .. friggin trashy people. I did stuff with their daughter
  14. #14 Re: Can any1 tell me what this noise is?
    Feb 2013
    Missoula, MT
    Its the the rings supported by the flat springs on the outer most part of the pulley that get engaged by the electromagnetic clutch. It didn't take much at all to bend but make sure it still engages.
  15. #15 Re: Can any1 tell me what this noise is?
    Dec 2012
    At first I thought it was just the two slightly touching making that noise, putting oil on it stopped the noise. But they do actually have bearing problems. They get so bad that plate actually gets so much play in it that it gets like a quarter of an inch away from the pulley and still makes the noise.
    You cant tell in the picture of my friends buick, but I could take that outer plate, and move it back and forth by hand it had so much play. Those are metal shavings around it. This is after putting oil on it, and the noise stopped.
    Sold.
  16. #16 Re: Can any1 tell me what this noise is?
    Feb 2013
    Missoula, MT
    Now thats defiantly not a quick fix
  17. #17 Re: Can any1 tell me what this noise is?
    Dec 2012
    No it was a temporary setback. It made it last a while longer, but he's still due for a new compressor.
    Sold.
  18. #18 Re: Can any1 tell me what this noise is?
    Jan 2013
    west palm
    wd-40 did the trick, i really didnt think it would be the ac clutch because of the fact of the noise not changeing when the ac was on or off. No more noise now so were good, Thanks
  19. #19 Re: Can any1 tell me what this noise is?
    Dec 2012
    lol wd-40 was the first thing I tried on mine. I did work but only lasted a week or two before making noise again, that's why I'm using engine oil, it doesn't evaporate.
    Sold.
  1. Any1 Know This Dragway?
    By GTPJOE90 in forum Midwest
    Last Post: 05-12-2010, 12:49 PM
  2. where do i tap into with this also does any1 run this now?
    Last Post: 10-20-2009, 09:26 PM
  3. PLEASE HELP any1 know grand ams?
    Last Post: 02-08-2009, 12:22 AM
  4. any1 been on this site?
    Last Post: 10-12-2008, 08:07 PM
  5. Can any1 help?
    By GTPJOE90 in forum General Tech Discussion
    Last Post: 10-02-2008, 12:24 AM
