Thread: Header install question almost done!
Results 1 to 20 of 59
  1. #1 Re: Header install question almost done!
    Banned
    Jan 2013
    Colorado
    So what was the best way you found to remove the rear manifold? I would assume you dropped it out the bottom correct?
  2. #2 Re: Header install question almost done!
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    Quote Originally Posted by camopaint0707 View Post
    Yeah pull the front manifold off first, then the cross over, pull the downpipe, and lower the subframe to get at the rear manifold bolts is what I did. If you just follow Bills write up it wont steer ya wrong.
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  1. header install ?'s
    By taman86 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2011, 12:16 AM
  2. Header Install
    By chrisgsx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-07-2010, 05:22 PM
  3. SD Header Install Soon...
    By theshznt69 in forum 04+ Specifics
    Last Post: 05-23-2010, 05:28 PM
  4. ZZP Header Install
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2010, 09:08 PM
  5. Header Install
    By GP_Kid18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2009, 11:12 PM
