Thread: Header install question almost done!
Page 1 of 3 123 LastLast
Results 1 to 20 of 59
h0wl0ngcanitbe Header install question... 06-19-2013, 10:44 PM
Fivefingerdeathpunch Re: Header install question... 06-19-2013, 10:48 PM
camopaint0707 Re: Header install question... 06-19-2013, 10:52 PM
h0wl0ngcanitbe Re: Header install question... 06-19-2013, 11:01 PM
Fivefingerdeathpunch Re: Header install question... 06-19-2013, 11:03 PM
h0wl0ngcanitbe Re: Header install question... 06-19-2013, 11:08 PM
camopaint0707 Re: Header install question... 06-19-2013, 11:10 PM
h0wl0ngcanitbe Re: Header install question... 06-19-2013, 11:31 PM
camopaint0707 Re: Header install question... 06-19-2013, 11:41 PM
h0wl0ngcanitbe Re: Header install question... 06-20-2013, 12:22 AM
camopaint0707 Re: Header install question... 06-20-2013, 12:32 AM
h0wl0ngcanitbe Re: Header install question... 06-20-2013, 12:34 AM
camopaint0707 Re: Header install question... 06-20-2013, 12:55 AM
camopaint0707 Re: Header install question... 06-20-2013, 12:53 AM
h0wl0ngcanitbe Re: Header install question... 06-20-2013, 02:53 AM
BillBoost37 Re: Header install question... 06-20-2013, 05:22 AM
h0wl0ngcanitbe Re: Header install question... 06-20-2013, 10:23 AM
Fivefingerdeathpunch Re: Header install question... 06-20-2013, 12:21 PM
BillBoost37 Re: Header install question... 06-20-2013, 12:37 PM
h0wl0ngcanitbe Re: Header install question... 06-20-2013, 01:56 PM
BillBoost37 Re: Header install question... 06-20-2013, 02:00 PM
h0wl0ngcanitbe Re: Header install question... 06-20-2013, 08:38 PM
BillBoost37 Re: Header install question... 06-21-2013, 06:18 AM
2000gtpbt Re: Header install question... 06-23-2013, 10:23 AM
h0wl0ngcanitbe Re: Header install question... 06-23-2013, 03:14 PM
h0wl0ngcanitbe Re: Header install question... 06-24-2013, 09:39 PM
Fivefingerdeathpunch Re: Header install question... 06-24-2013, 09:40 PM
h0wl0ngcanitbe Re: Header install question... 06-24-2013, 10:54 PM
Scottydoggs Re: Header install question... 06-24-2013, 10:58 PM
h0wl0ngcanitbe Re: Header install question... 06-24-2013, 11:03 PM
h0wl0ngcanitbe Re: Header install question... 06-25-2013, 12:11 AM
Fivefingerdeathpunch Re: Header install question... 06-25-2013, 12:13 AM
h0wl0ngcanitbe Re: Header install question... 06-25-2013, 12:29 AM
h0wl0ngcanitbe Re: Header install question... 06-25-2013, 12:17 AM
Fivefingerdeathpunch Re: Header install question... 06-25-2013, 12:20 AM
h0wl0ngcanitbe Re: Header install question... 06-25-2013, 12:22 AM
Fivefingerdeathpunch Re: Header install question... 06-25-2013, 12:31 AM
h0wl0ngcanitbe Re: Header install question... 06-25-2013, 02:54 AM
Slick2500 Re: Header install question... 06-25-2013, 04:14 AM
h0wl0ngcanitbe Re: Header install question... 06-25-2013, 05:22 AM
Slick2500 Re: Header install question... 06-25-2013, 01:19 PM
h0wl0ngcanitbe Re: Header install question... 06-25-2013, 03:07 PM
h0wl0ngcanitbe Re: Header install question... 06-26-2013, 12:55 AM
Z34Phoenix Re: Header install question... 06-26-2013, 08:37 AM
Bio248 Re: Header install question... 06-26-2013, 08:39 AM
Travisgt2 Re: Header install question... 06-26-2013, 08:44 AM
REDCRAPGP Re: Header install question... 06-26-2013, 08:45 AM
dsmuts Re: Header install question... 06-26-2013, 08:45 AM
Bio248 Re: Header install question... 06-26-2013, 08:47 AM
h0wl0ngcanitbe Re: Header install question... 06-26-2013, 10:05 AM
h0wl0ngcanitbe Re: Header install question... 06-26-2013, 04:55 PM
REDCRAPGP Re: Header install question... 06-26-2013, 05:10 PM
h0wl0ngcanitbe Re: Header install question... 06-27-2013, 12:43 AM
REDCRAPGP Re: Header install question... 06-27-2013, 01:03 AM
h0wl0ngcanitbe Re: Header install question... 06-27-2013, 01:39 AM
REDCRAPGP Re: Header install question... 06-27-2013, 05:01 AM
h0wl0ngcanitbe Re: Header install question... 06-27-2013, 09:55 AM
REDCRAPGP Re: Header install question... 06-27-2013, 09:59 AM
REDCRAPGP Re: Header install question... 06-27-2013, 10:02 AM
  1. #1 Header install question almost done!
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    So I got the old manifold out whew that was a trek!
    Im ready to start reassembling everything with the new ZZP headers. My question is where should I apply RTV? On all surfaces that touch the block? Or just on the gaskets?
    Any last minute tips before I tackle this install??
    Of coarse gotta give ya guys something!!
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  2. #2 Re: Header install question almost done!
    No rtv on the gaskets, just re-use the factory gaskets.
    You can put a small bead around the 1 slip fit joint on those headers and then a band clamp. The 1 v-band clamp for the downpipe needs nothing either.
  3. #3 Re: Header install question almost done!
    Banned
    Jan 2013
    Colorado
    nice
  4. #4 Re: Header install question almost done!
    Marysville WA
    One last question, what if I cant get the header studs out? Ive stripped x2 5.5mm sockets trying to get #2 out on the front side. The first one came out easy enough but im afraid of screwing up these studs. Is it the end of the world if I dont free up those gaskets? I know it sounds half assed but again x5.5mm sockets. Tired of goin to the parts store for the same part!
  5. #5 Re: Header install question almost done!
    I left the studs in and re-used all the stock bolts/nuts when I installed my headers.
  6. #6 Re: Header install question almost done!
    Marysville WA
    Ok thanks FFDP here goes nothin!
  7. #7 Re: Header install question almost done!
    Banned
    Jan 2013
    Colorado
    What other snags did you run into during this install?
  8. #8 Re: Header install question almost done!
    Marysville WA
    Ok so in your guys experience whats the easiest way to get the rear header in? Top side or bottom? And is there a limit to how much i can lower the subframe. Ive never done that and I just dont to lower it too far. This rear header goin in is like an evil effen rubix cube!
    camopaint this only real snags have been contorting my body in ungodly position both under and over my ride to get at the header bolts. Not gonna lie the rear almost had me done in. Its just a series of patience and relaxing to get at some of the bolts. Otherwise its been pretty easy, mind you im a total newb at mechanical stuff Ive never done this kind of work so my lack of confidence has been an issue but ive just been taking my time and referencing GPF. Thank the gods for Bill
  9. #9 Re: Header install question almost done!
    Banned
    Jan 2013
    Colorado
    So what was the best way you found to remove the rear manifold? I would assume you dropped it out the bottom correct?
  10. #10 Re: Header install question almost done!
    Marysville WA
    Quote Originally Posted by camopaint0707 View Post
    Yeah pull the front manifold off first, then the cross over, pull the downpipe, and lower the subframe to get at the rear manifold bolts is what I did. If you just follow Bills write up it wont steer ya wrong.
  11. #11 Re: Header install question almost done!
    Banned
    Jan 2013
    Colorado
    do you have a link for it? I couldn't find it
  12. #12 Re: Header install question almost done!
    Marysville WA
    Badda bing!
    http://www.grandprixforums.net/how-i...hod-44126.html
  13. #13 Re: Header install question almost done!
    Banned
    Jan 2013
    Colorado
    Ok now I remember this write up.
  14. #14 Re: Header install question almost done!
    Banned
    Jan 2013
    Colorado
    Looking in the wrong section lol
  15. #15 Re: Header install question almost done!
    Marysville WA
    Well I got the rear header in, tip... pull the trans dip stick. Albeit its a mother to get that trans dip stick to mount back up (due to the new cross over blocking the access to the bolt for the mount) it allowed the header to slide right in! Thats it for tonight hope to get this finished up tomorrow.
  16. #16 Re: Header install question almost done!
    I didn't have to pull the dipstick...I allowed the header to massage it. The ZZP was a little more of a challenge than SD's. The writeup is more SD than ZZP. On the zzp, as you bring it up and in.. try to bend the EGR tube to start aiming in the right direction. Bing bang boom..you should be done.
  17. #17 Re: Header install question almost done!
    Marysville WA
    Heh thanks Bill for that heads up cause I was scratchin the crap outta my head when my EGR didnt line up after I got the rear header in. So I take it its a flex tube that can be bent slightly.
    I must note that my trans dip stick does clearly hit. From what I read this will cause false KR correct? What is my solution to this bend the trans dip stick?
  18. #18 Re: Header install question almost done!
    Yeah, carefully bend it to clear the headers.
  19. #19 Re: Header install question almost done!
    If it's clanking..yes..if it's solid..no Be careful of where the tab is welded to it. That likes to crack and leak at that point. And yes on the egr tube. It's a bit more of a bend than I was comfy putting into the tube, however I had 3-4 sitting on the shelf so I didn't really sweat it.
  20. #20 Re: Header install question almost done!
    Marysville WA
    When you say solid do you mean if the trans dip stick is literally pressed against the cross over to not worry about it. There is little to no movement of the dip stick against the cross over they are pretty buddy buddy right now.
  1. header install ?'s
    By taman86 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2011, 12:16 AM
  2. Header Install
    By chrisgsx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-07-2010, 05:22 PM
  3. SD Header Install Soon...
    By theshznt69 in forum 04+ Specifics
    Last Post: 05-23-2010, 05:28 PM
  4. ZZP Header Install
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2010, 09:08 PM
  5. Header Install
    By GP_Kid18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2009, 11:12 PM
