Thread: Header install question almost done!
Results 21 to 40 of 59
  1. #21 Re: Header install question almost done!
    Yeah.if it can't move..it can't rattle and it can't cause KR
    Worst case..you see kr and manhandle it then.
  2. #22 Re: Header install question almost done!
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    Does anyone have a link to the bolt pattern/ order of which order we use which header bolt? Pulling the rears I didn't do a good job tracking as I was just excited to get them out!
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  3. #23 Re: Header install question almost done!
    Snug them all.. then tighten them ... you don't need a pattern.
  4. #24 Re: Header install question almost done!
    SE Level Member 2000gtpbt's Avatar
    Mar 2012
    Alexandria, MN
    Did you get them? Pics? How do they sound any leaks?
    Any man who can drive safely while kissing a pretty girl is simply not giving the kiss the attention it deserves.
    Albert Einstein
  5. #25 Re: Header install question almost done!
    Marysville WA
    Quote Originally Posted by 2000gtpbt View Post
    Ran out of time last week and had a weekend long wedding so that took up my time, stay tuned ill get them done!
  6. #26 Re: Header install question almost done!
    Marysville WA
    Is this the correct order for spark plug wires?
    https://www.google.com/search?q=pont...ml%3B792%3B516
  7. #27 Re: Header install question almost done!
  8. #28 Re: Header install question almost done!
    Marysville WA
    Runnin into issues with the front, im starting to think I should have seated those first....
    The issue is no matter how far I drop the sub I cant get enough room to clear the front passenger side header post
    And to top it off this guy is a PITA
    Any suggestions, do I just need to rock the crap out of the motor and wiggle it in or do you guys have any tips?
  9. #29 Re: Header install question almost done!
    you cant push the engine back to the fire wall any further? then hit the cross over with a rubber mallet to seat it in the other pipe there.
    thats kinda how i recall Bills how to read.
  10. #30 Re: Header install question almost done!
    Marysville WA
    So I can let that sub frame drop as far as it can go? Its just tough getting room for a mallet gawd I hope I dont have to dismantle the rear header I felt so accomplished after finishing that up!
  11. #31 Re: Header install question almost done!
    Marysville WA
    Yeah im stuck on this front header... I just cant get this header to clear the studs to mount up. How hard is it to remove the radiator........
  12. #32 Re: Header install question almost done!
    Try using a pry bar to get things to move around.
  13. #33 Re: Header install question almost done!
    Marysville WA
    Im down to try that but im so new to motors I feel like id do more damage then good if I start fishing around a prybar. If you were to recommend a location to prybar would it be like below the crossover against the tranny?
  14. #34 Re: Header install question almost done!
    Is it possible to stick the pry bar in the cylinder 1 on the header and use the that upper dog bone mount/coil mount as a pry spot, then push the headers out and then down to line up the bolt.
  15. #35 Re: Header install question almost done!
    Marysville WA
    Let me give that a whirl hang on BRB....
  16. #36 Re: Header install question almost done!
    Marysville WA
    Fivefingerdeathpunch
    SEND ME YOUR ADDRESS CAUSE IM SENDING YOU (AND BILL) A CASE OF BEER!
    That pry bar tricked worked like a charm! Now back to the grind hopefully ill have this wrapped up tonight!!
  17. #37 Re: Header install question almost done!
    Pry bars are one of my favorite tools.
  18. #38 Re: Header install question almost done!
    Marysville WA
    Indeed!
    Update, im almoset ready to fire this bad boy up but I cant get the dog bones to mount up??? Nothin is jacked everythin is mounted and no matter what I cant get the dog bones to line up! Is this common?
  19. #39 Re: Header install question almost done!
    What do you mean they wont line up?
  20. #40 Re: Header install question almost done!
    Marysville WA
    Quote Originally Posted by slick2500 View Post
    Heh it means im still hella newb status and forgot to lower the car on all fours... Shes all buttoned up and fired up first go, a lil tranny oil burned off since I pulled the tranny dip stick. Aside from that everything worked out great she sounds like a beast with the whole ZZP back setup! Cant wait to put up a video for you guys. Ill give a few days to settle in. Only thing I forgot to do was the downpipe gasket to the res but that will take a second later this week.
    Thanks all for you help guys cheers to helpin newbs pimp out there rides!
  1. header install ?'s
    By taman86 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2011, 12:16 AM
  2. Header Install
    By chrisgsx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-07-2010, 05:22 PM
  3. SD Header Install Soon...
    By theshznt69 in forum 04+ Specifics
    Last Post: 05-23-2010, 05:28 PM
  4. ZZP Header Install
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2010, 09:08 PM
  5. Header Install
    By GP_Kid18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2009, 11:12 PM
