Thread: questions regarding cam install
Results 1 to 4 of 4
  1. #1 questions regarding cam install
    Jun 2013
    pittsburgh
    Hello, I'm installing a cam into a L67 and have a few questions. First, does the dot on the balance shaft point up or down when the timing marks align? Second, does the oil hole on the lifters point towards the front or back of the block? Thanks!
  2. #2 Re: questions regarding cam install
    GT Level Member mkyota1's Avatar
    Daytona, florida
    Balance shaft dot goes down. You will see the dot on the cam gear after you remove the cam timing sprocket.
    Im pretty sure it does not matter which way the hole goes but try to keep them the same for wear pattern reasons.
  3. #3 Re: questions regarding cam install
    ^^ Yup. Dots touch on cam to balance drive gears and then cam to crank gears. Agree on lifters as well.
  4. #4 Re: questions regarding cam install
    Jun 2013
    pittsburgh
    thank you Gentlemen!
  1. I am looking to install an aftermarket HU...just some questions.
    By 08GPguy in forum Audio, Security & Visual Electronics
    Last Post: 06-01-2012, 09:22 PM
  2. Questions after powerlog install.
    By Bluemagic in forum General Tech Discussion
    Last Post: 05-27-2012, 09:05 PM
  3. questions regarding aftermarket install
    By bkatrenak in forum Audio, Security & Visual Electronics
    Last Post: 03-11-2011, 07:22 AM
  4. intercooler install questions
    By screamingreenmonster in forum General Tech Discussion
    Last Post: 05-17-2010, 05:17 PM
  5. ZZP MPS Install questions
    By Liquifire in forum General Tech Discussion
    Last Post: 10-13-2009, 02:21 PM
