Balance shaft dot goes down. You will see the dot on the cam gear after you remove the cam timing sprocket.
Im pretty sure it does not matter which way the hole goes but try to keep them the same for wear pattern reasons.
^^ Yup. Dots touch on cam to balance drive gears and then cam to crank gears. Agree on lifters as well.
thank you Gentlemen!
