Thread: Built motor is blown (video) and buying a L26 for now and moving all my things to it
Page 1 of 3 123 LastLast
Results 1 to 20 of 53
  1. #1 Built motor is blown (video) and buying a L26 for now and moving all my things to it
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    coasting in my neighborhood the cam was about to make the car stall with its lumpiness I gave it a 20-25% throttle jump to keep it going I notice 10 seconds later the DIC says low oil PSI and the light is on in the cluster FU.CK mode active. turn car off. waited 5 minutes tried to start it and no lights for oil. drive it the 100 feet to my drive way and let it idle and gave it a quick rev and thats when i got to hear my heart and head explode. It sounds nice and fine before 2.2k. I changed the oil, more metal in it third change in 300 miles. start car again now its a bit more quiet and sounds like its coming from the top end.
    RAAAAAAAAAAAAAAAAAAAAAAAAAAAGGGGGGGGGGGGGGGGGGGGGG GGGGGGGEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE QUIT
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  2. #2 Re: SO I put 300 miles on the new engine and now it has a knock/tap sound, kill me.
    So its the machine shops fault then.
  3. #3 Re: SO I put 300 miles on the new engine and now it has a knock/tap sound, kill me.
    GT Level Member Toms04compg's Avatar
    Michigan
    With all the metal shavings still around that long.
  4. #4 Re: SO I put 300 miles on the new engine and now it has a knock/tap sound, kill me.
    Michigan
    Sounds like you didn't change your oil pump.
  5. #5 Re: SO I put 300 miles on the new engine and now it has a knock/tap sound, kill me.
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    And this is why a stock bottom end is better than building a motor...
    That sucks.
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  6. #6 Re: SO I put 300 miles on the new engine and now it has a knock/tap sound, kill me.
    Apr 2012
    Middletown DE
    Quote Originally Posted by Toms04compg View Post
    Just curious why would I need to change an oil pump with only 69k on it?? I changed the oil the first time with 60 miles on it then again tonight with 240 on that.
    1993 Oldmobile 88
  7. #7 Re: SO I put 300 miles on the new engine and now it has a knock/tap sound, kill me.
    Michigan
    Sounds like there could have been some of those shavings in your pick up tube... pump ect. How doesn't that make sense?
  8. #8 Re: SO I put 300 miles on the new engine and now it has a knock/tap sound, kill me.
    Quote Originally Posted by buck531 View Post
    That sucks.
    Only if you neglect it and didn't do it right.
    If it was totally built from a bare block...and the mains weren't line bored...then lol, yup. 300~ mile miracle.
  9. #9 Re: SO I put 300 miles on the new engine and now it has a knock/tap sound, kill me.
    Michigan
    Metal shavings in your oil for 60 miles bro nuff said.
  10. #10 Re: SO I put 300 miles on the new engine and now it has a knock/tap sound, kill me.
    Apr 2012
    Middletown DE
    Metal shavings in your oil for 60 miles bro buff said.
    I am a bit tired atm
    are you trying to say that I should have changed it when I did the rebuild or I will need to change it now?
    1993 Oldmobile 88
  11. #11 Re: SO I put 300 miles on the new engine and now it has a knock/tap sound, kill me.
    GTP Level Member L36 Killer's Avatar
    Jul 2012
    Harrisburg, Pennsylvania, United States
    Sorry to hear man. Sub'd for future success!
    "SHELLY" GRAND PRIX GT 02. SLP HEADERS & EXHAUST, K&N CAI, BMR REAR SUSPENSION AND STRUT BRACES, 180 T-STAT, AGX STRUTS, EIBACH SPRINGS, OVERKILL PCM, YELLA TERRA 1.7 ROCKERS, GT1 CAM, SEXMAN PORTED & POLISHED HEADS, STAGE 2 PORTED TB
  12. #12 Re: SO I put 300 miles on the new engine and now it has a knock/tap sound, kill me.
    Michigan
    Should have on the rebuild bro... especially since you sound like you spun an rb to start with. Good luck bro
  13. #13 Re: SO I put 300 miles on the new engine and now it has a knock/tap sound, kill me.
    Michigan
    Did you crank it a bit just to get oil flowing before initial start up? If you didn't I suggest you try it this time. Pull your fuel pump fuse and do like 10 sets of 15 second cranks. Use 10w30 non syn on your break in oil.
  14. #14 Re: SO I put 300 miles on the new engine and now it has a knock/tap sound, kill me.
    Apr 2012
    Middletown DE
    We cranked it for about 5 minutes 30 seconds at a time with 20 second breaks in between. with 10w30 no syn with GM E O S mixed in with the oil
    1993 Oldmobile 88
  15. #15 Re: SO I put 300 miles on the new engine and now it has a knock/tap sound, kill me.
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    all these horror stories with top/swaps/ builds are starting to scare me.
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  16. #16 Re: SO I put 300 miles on the new engine and now it has a knock/tap sound, kill me.
    Apr 2012
    Middletown DE
    Quote Originally Posted by Grimsin View Post
    Just make sure you use headers and a tune. You will be ok
    1993 Oldmobile 88
  17. #17 Re: SO I put 300 miles on the new engine and now it has a knock/tap sound, kill me.
    Slower, Lower Delaware
    Wow, sorry to hear that. Good luck.
  18. #18 Re: SO I put 300 miles on the new engine and now it has a knock/tap sound, kill me.
    Apr 2012
    Middletown DE
    I'm shopping for a l36 26 to throw in. I'm doing a V8 car mod. ****ing having any extra money.
    1993 Oldmobile 88
  19. #19 Re: SO I put 300 miles on the new engine and now it has a knock/tap sound, kill me.
    SE Level Member JerzNick's Avatar
    Oct 2012
    New Jersey
    Sorry to hear man. I feel your pain, I'm on engine #3 myself. I have an L36 with tranny sitting on my garage floor, approx 72k on it when pulled. Selling for cheap if your interested.
    Bored block, Eagle Crank, XP Cam, Ported Heads/LIM/Blower/TB, 3.0 Pulley, CAI, Headers, 42.5#, AL 104's, etc...
  20. #20 Re: SO I put 300 miles on the new engine and now it has a knock/tap sound, kill me.
    Feb 2009
    flintnasty MI
    The metal shavings in the oil were from the first second you built the motor... Something was grinding and its not going to stop.. usually a grinding bearing will last about 300-500 miles before it falls apart enough to knock.
  1. 4th engine with rod knock
    By RideWithPride in forum General Grand Prix Discussion
    Last Post: 05-26-2013, 11:34 AM
  2. Need help engine knock??
    By thomasd2010 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-28-2012, 04:34 PM
  3. New rebuilt engine rod knock sound only 75 miles broken in
    By RideWithPride in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-08-2012, 06:18 AM
  4. Engine Knock
    By tdm571 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-22-2011, 07:49 PM
  5. Hey what exactly does knock sound like ?
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 09-20-2010, 02:03 PM
