Thread: Engine Knock
Page 1 of 3 123 LastLast
Results 1 to 20 of 51
  1. #1 Engine Knock
    GT Level Member tdm571's Avatar
    Lakeside Park, KY
    Here's the long saga on my 97SE. Sorry in advance for the length. Purchased it in Dec '10. Speedo read 60k, but the previous owner just put an engine in with 50k. I upgraded to the Digital DIC. All I got was flashing zeros and flashing "Trac Off" light when I hit the gas. Tried several 97 DICs, including a known working unit from my good GP, same result. Changed out all four hubs, rotors, pads, and ECBM. Still same result. It was suggested that the PCM was stuck in programming mode. So, I got me one and changed it out. Finally, the DIC was working. Was driving home, everything running great, didn't push it at all. Then, about 2 miles from home, going up a hill on the expressway, I started losing power, SES light starts flashing. So, I get her home and check the codes. Got a P0304. Naturally, I came here and checked it out. Changed the plugs and wires along with the A/C compressor and accumlator/drier. I clear the codes and start her up. On start up, it sounds really rough and I get the flashing SES and the engine sounds like it is knocking. Now, I change out the coils. Clear the codes and start her up again. Still rough and knocking but no SES light. I took her for a 10-15 mile ride. Power sucked, tranny kept shifting at higher RPMs, and the engine was knocking. Sounds like it's in the rear/firewall side. Before I go any further, did I blow a piston? Here's a couple of videos of the know:
    From the inside of the car:
    From under the hood:
  2. #2 Re: Engine Knock
    Quincy, Mass
    sounds like a bearing.
    No more GP 04 Impala SS Indy:
  3. #3 Re: Engine Knock
    I feel like we should have a "need a new motor" section today.
    I don't need one..but there's a hippo and yourself that do.
  4. #4 Re: Engine Knock
    Lakeside Park, KY
    How does a 50k mile engine blow a bearing without being run hard? This was my wife's car, not mine.
  5. #5 Re: Engine Knock
    The junkyard motor wasn't in good shape when they tossed it in?
    That's what it sounds like to me.
    Also...flashing 0.0's on the DIC...last I checked that means the PCM is in programming mode...so, that's odd.
  6. #6 Re: Engine Knock
    Lakeside Park, KY
    Well, putting another engine in is not in the budget nor within my selection of tools to perform. I hate getting rid of a car that I've only had 8 months.
  7. #7 Re: Engine Knock
    all you need is a 30 piece socket set and you could pull one of these engines, if you dont have a engine picker (hoist) a come along tied to the rafters of the garage would do if needed, hell if you got 2 or 3 friends i bet the 3 of ya could just lift it out of the engine bay if you put a 4x4 across the engine with some chains, if there's a will there's a way.
    im sure you could find a used engine whole for around 400 clams.
  8. #8 Re: Engine Knock
    Quote Originally Posted by tdm571 View Post
    I fail to see how you can't see the problem.
    Seriously though, things happen. it's not very common for one to give up like that though. Another thing to consider. GM changed some programming from time to time during each model year to refine things. It's possible your programming has more timing or something else that beat the bearings. Seems that two motors both about 50K on them give up..hmmm
  9. #9 Re: Engine Knock
    Lakeside Park, KY
    The reason her driving is not a problem is because I doubt she ever reaches half throttle, much less WOT. She *****es whenever I give my car enough gas to downshift. LOL
    Being unemployed really prohibits another engine. On the upside, it is a spare vehicle. The wife will just have to go back to the minivan.
  10. #10 Re: Engine Knock
    Jun 2011
    Detroit, MI
    True... haha
    iLoveSpade
  11. #11 Re: Engine Knock
    off topic but how do you get the videos to play?
    SMGPFC Member #10
  12. #12 Re: Engine Knock
    Jun 2011
    Detroit, MI
    Click them.
    iLoveSpade
  13. #13 Re: Engine Knock
    i do that and it goes to a pop out and acts like a pic and doesnt do anything
    SMGPFC Member #10
  14. #14 Re: Engine Knock
    Jun 2011
    Detroit, MI
    It does that but opens another page with the video on it for me haha.
    iLoveSpade
  15. #15 Re: Engine Knock
    Quincy, Mass
    pull the valve covers off that could be something easy. it doesnt sound too bad and could be a bad lifter, pushrod, or rocker.
  16. #16 Re: Engine Knock
    I live here. TLSheff's Avatar
    Quote Originally Posted by Swiggles View Post
    Always possible but I would put money that his is the same as mine. My GTPs first engine made it to 83k before I got off the highway wondering why my car sounded like a deisel. Been flawless up to a random point where I spun cyl#1 main bearings and fubar'd the crank.
    Tech at work knows I have tracked the car a couple times but said it was most likely the previous owners flawed maintenance vs my own because I work on it at the shop during lunch breaks. Didn't stop the bearing from going out.
    A bad engine is a bad engine, and owner maintance has alot to do with that. You got a bad engine put into it, sux but it happens. Like they said, it can be replaced overnight with friends if you don't have the tools. Hell me and my friend lifted the whole bad motor out of the back of the truck and toted it into the garage by hand... was heavy but we did it.
  17. #17 Re: Engine Knock
    Don't mean to be beating a dead horse to death...but its a killer.
    That's the noise a bearing makes after its shreded and it spinning around the crank journal...
  18. #18 Re: Engine Knock
    Assuming you didn't continue running it very long, and completely destroy the bearing and crank like I had to, it might be fixable. Mine scratched out the crank to the point we just replaced the motor. this was the bearings after I had to drive it home off the highway and then another 15 miles back to work the next day. All in all about 25 miles after I noticed the clanking.
    New to me motor that was thoroughly checked over is rocking strong 12k later *fingers still crossed*
    I have them sitting on my comp tower at home fitted together, the ends happen to overlap the others to hold themselves together nicely... scary as that is lol, nice little keep sake
  19. #19 Re: Engine Knock
    I've got a couple busted spark plugs, chunks of piston and piston rings that are fused together...a head with a spark plug melted in it...bent pushrod...and a few busted/melted valves, and a cam bearing that is totally flat in 2 peices.
    yay 3800.
  20. #20 Re: Engine Knock
    yay 3800.
    You just made these cars sound like POS's
  1. Engine knock???
    By MagnoliaMak in forum General Tech Discussion
    Last Post: 03-15-2011, 07:52 PM
  2. GTP Engine Knock..... sigh....
    By Soeasytobefake in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-16-2010, 02:20 PM
  3. 3.8 Surpercharged Engine Knock.
    By bigmike0071 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-15-2009, 04:44 PM
  4. Need help, Engine Knock
    By valleyd01 in forum General Tech Discussion
    Last Post: 10-02-2009, 06:28 PM
  5. Do I have Engine knock?
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2008, 07:59 AM
