Thread: Gen v N* lq4 maf gains
Results 1 to 10 of 10
  1. #1 Gen v N* lq4 maf gains
    Banned
    Jan 2013
    maryland
    Wanted to know with swapping to the gen v what gains for whp? Ive heard 20 crank hp but what on the dyno sheet how much whp? thats on a l32 setup does this apply to the l67 as well? N* LQ4 Maf whp gains? Thought i'd ask being as tho im doin this swap
    Sent from my SGH-T989 using Tapatalk 2
  2. #2 Re: Gen v N* lq4 maf gains
    There really isn much benefit to goin genV unless youre sub 3.0-3.1 pulley on a genIII... ya its more efficient but untill you get down to the smaller pullies, youre not taking advantage of the efficiency gain. Its the same with the TB/maf... if youre not outflowing a stock TB/maf... there wont be any advantage to upgrading.
  3. #3 Re: Gen v N* lq4 maf gains
    Banned
    Jan 2013
    maryland
    So what you are saying is that there isnt a reason to swap to a gen v n* lq4 and i wont feel a "difference" just more "whine" unless i drop lower pullies?
  4. #4 Re: Gen v N* lq4 maf gains
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    The reason the Gen V gets your 15 - 20 HP is because of the effiencey of it. For the price of the Gen V, LIM, Gaskets, ECT... You can get the same gains by dropping to a 3.6ish pulley on a Gen III... That's what he's saying... It's more practical to swap once you've droped pulley size considerably.
    3.8" GenV = 3.6" GenIII
    As for the N* LQ4 combo, I have it on my car. Throttle response is noticable, but it wears my leg out because it's a loose throttle.. LOL I feel myself holding my foot up if that makes sense...
    What other mods do you have already?
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  5. #5 Re: Gen v N* lq4 maf gains
    Banned
    Jan 2013
    maryland
    Quote Originally Posted by dbextreme View Post
    3.4 pulley sd headers exhaust 105# springs xp cam single rollermaster chain intake tune could get gains dropping to a 3.2 3.0 for the gen v n* lq4 setup?
  6. #6 Re: Gen v N* lq4 maf gains
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    If your throttle is mushy, just add another spring to the TB.
  7. #7 Re: Gen v N* lq4 maf gains
    Nov 2009
    Tennessee
    Quote Originally Posted by jayroca View Post
    It would benefit you more then someone stock. As for how much others would have to chime in.. I'm running a Gen III ATM..
    If you don't mind me asking, if you have a boost gauge, what boost are you getting on your current setup?
    Quote Originally Posted by addzradd View Post
    Thanks, thought about it. Other then that it feels great!!
  8. #8 Re: Gen v N* lq4 maf gains
    I dont see you being able to run that low of a pulley on a genV with that mod list. As far as switching to a genV in general, it's not gonna hurt anything, but its not gonna help much either as you would need to run ~3.6 since you have a 3.4 on a genIII. A genV swap is not like putting on headers or a cam in regards to a set hp gain. Same with the TB, you wont gain X amount of hp by just slapping on a bigger one. You might feel a difference in "throttle response" (even though you aren really improving it with a N*, it just seems like it with the blade opening quicker than stock). When I went genV i switched TBs as well simply because it was easier to install than messing with the other adapter stuff at the time.
  9. #9 Re: Gen v N* lq4 maf gains
    Banned
    Jan 2013
    maryland
    Quote Originally Posted by gtpsleeper View Post
    What i need to run lower pullies? i thought that setup would be enough Could i do e85? Are my injectors maxed out to go to 42lbs? Ive seen similar builds thats why i asked
  10. #10 Re: Gen v N* lq4 maf gains
    to go e85 youd need to step up to 60lb injectors. Why are you so worried about what pulley to run? Run the smallest you can with 18-20* of timing and an AFR 11.5-11.6 (obviously this can very some). That may be a 3.0 or a 3.4... the reality is that there is just no way to tell until you do it.
  1. ZZP vs cam setup...Gains?
    By OrangeL67 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-15-2012, 11:18 PM
  2. where is my power gains??????
    By novmadman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2011, 09:33 AM
  3. Porting gains
    By jakewet28 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-22-2010, 06:49 PM
  4. what do you think the gains will be
    By nascartech in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-15-2010, 12:43 AM
  5. N* gains
    By gtpsleeper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2009, 09:50 AM
