Something else I keep seeing on other forums is bypassing the Fuel pump resister. I pull the relay and jump connection 87 and 30 but it wont even start. I'm assuming this is not the correct pins to jump. The pump wont even come on. If I jump pins 30 and 87 on the main fuel pump relay the pump runs, even with the key off, and starts then dies after a couple of seconds.
