Thread: 2000 GTP with a 97 engine problems
Results 1 to 11 of 11
  1. #1 Re: 2000 GTP with a 97 engine problems
    Mar 2013
    Meridian, Idaho
    UPDATE: Ok, I just finished pulling all the vacuum lines off and checking them. They are good. I pulled the fuel rails and replaced the injector O-rings just to make sure they weren't sucking air. I check the wiring as best I could, it all looks good. I checked all the plugs and wires, they looked good and fire strong.
    When I start the car it runs a couple of seconds and dies, I'm getting no codes at this point, doesn't seem to run long enough to trip one. I unplug the MAF and and it does exactly the same, starts and runs a couple of seconds then dies.
  2. #2 Re: 2000 GTP with a 97 engine problems
    Mar 2013
    Meridian, Idaho
    Sorry for all the posts, but I think I have it fixed, sorta. So pulled Relay 15, the Fuel Pump Speed relay and bent pin 85 out and reinstalled the relay. The car now runs. I will give it a day or two just to be sure. This bypasses the fuel pump speed resister which is the apparent culprit. Nice that I spent $500 to find this out. But I now have a lot of new stuff on the car.
    Thank you for all the suggestions, they were helpful.
  1. 2000 gtp multiple problems....HELP
    By tjfrey517 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2012, 07:29 AM
  2. 2000 Grand Prix GTP, PROBLEMS....PLEASE HELP....
    By Lawenforcer in forum General Tech Discussion
    Last Post: 05-30-2012, 04:25 PM
  3. 2000 GTP Problems
    By BThomp in forum General Tech Discussion
    Last Post: 08-22-2010, 07:36 PM
  4. Problems with AC on 2000 GP
    By Aerosmitty in forum General Tech Discussion
    Last Post: 07-20-2010, 09:28 AM
  5. DIC Problems in GT 2000
    By sirpig34 in forum Audio, Security & Visual Electronics
    Last Post: 08-05-2009, 09:41 PM
