Thread: help have engine knock.
Results 1 to 20 of 68
  1. #1 Re: help have engine knock.
    SE Level Member twentyocho's Avatar
    Feb 2013
    Amarillo
    I think i did. Can someone tell me what the specs are? I was thinkin 11ft.lbs + 90°... guess i'll be takin the valve cover off again tomorrow and recheckin everything..
  2. #2 Re: help have engine knock.
    SE Level Member kingjer's Avatar
    Mar 2013
    Slave Lake , Alberta
    Yup thats correct...Can you get your hands on leak down test ? That will tell you if you've got valve issue or not. I would also do compression test on that cyl
  1. 4th engine with rod knock
    By RideWithPride in forum General Grand Prix Discussion
    Last Post: 05-26-2013, 11:34 AM
  2. Engine Knock
    By chrisangelly1981 in forum Introductions/Noob Questions
    Last Post: 01-23-2013, 01:42 AM
  3. Engine knock???
    By MagnoliaMak in forum General Tech Discussion
    Last Post: 03-15-2011, 07:52 PM
  4. Need help, Engine Knock
    By valleyd01 in forum General Tech Discussion
    Last Post: 10-02-2009, 06:28 PM
  5. Do I have Engine knock?
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2008, 07:59 AM
