Thread: help have engine knock.
Page 4 of 4 FirstFirst ... 234
Results 61 to 68 of 68
  1. #61 Re: help have engine knock.
    SE Level Member twentyocho's Avatar
    Feb 2013
    Amarillo
    Quote Originally Posted by rafadavidc View Post
    rockauto.com has yours (had to dig through the thread to find your year/make/model) for $80 each, OEM.
    More Information for ACDELCO 2171389
    Thanks alot for the link Raf.. Got injectors switched and almost everything put back together but ran out of time so ill try and finish up tonite and see what happens. hopefully the injector was just plugged up or something.. Just need to put tensioner, ICM, coils, reconnect battery, and hook up wires then fire her up. Kinda just wondering if I should just take everything off since I'm already this far in and remove blower and LIM to replace gaskets and elbows.. Just don't want to start buying parts then come to find out I have a chipped piston or some crap like that..
  2. #62 Re: help have engine knock.
    Feb 2013
    Amarillo
    Well guys got everything back on after switching injectors and still getting a misfire on #3 come up with SES light just flashing on and off.. I'm at loss on what to do guys... any more advice and I'll try something else. Thnx in advance..
  3. #63 Re: help have engine knock.
    try swapping the spark plug and wire, do the wire first, then the plug, if that dont make the misfire move then swapping the coils around.
    sorry if this has been tried already. 4 pages deep now.
  4. #64 Re: help have engine knock.
    Feb 2013
    Amarillo
    Sorry Scotty posted that up right after shower and right before bed. Was out tinkering with this thing about 3 hours after getting home from work and still haven't a clue as to what could be wrong..
    Anyways here's what all I've done....
    1.First after iniatially hearing a mysterious knock turned out to be a loose rocker..
    1a. Removed valve cover and sure enough rocker on #3 was loose. retorqued it and knock eliminated..
    2. Noticed miss in car after tightening rocker. Went to get scanned. Got a 0303. Checked wires and plugs. Found a bad plug.
    2a. Replaced all plugs with OE iridiums..
    3. Still noticed a miss so went ahead and bought a scanner and scanned. Got a Po303-Powertrain Cylinder 3 misfire..
    3a. Swapped wires around again and no change.
    3b. Replaced wires and no change.
    3c. Swapped coil packs and no change.
    3d. Bought new coil pack to be certain and no change. Used electrical grease on connections eventhough no corrosion was noticeable.
    4. Rescanned and still getting a p0303-Powertrain Cylinder #3 misfire.
    4a. Removed valve cover and rechecked rocker to check torque spec at 11lbs. Rechechecked spring. All looked good.
    4b. Swapped fuel injectors in #1 and #3 to see if maybe bad injector. While doing this I noticed fluid on top of manifold with what seemed like a bit of antifreeze but not alot. Cleaned it up and cleaned injectors. Checked O rings. Good.
    4c. Put everything back together. Checked for leaks and anything I could of left loose or broke and all looked good. Hooked up battery and turned on ignition (without starting car) to pressurize fuel lines and rechecked for leaks. All looked good.
    4d. Checked oil level. Checked coolant . And fired her up. And absolutely no change. As if I hadn't even touched it. Rescanned and still a po303-Powertrain Cylinder 3 misfire..
    HELP!!!
  5. #65 Re: help have engine knock.
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    I'm sure you are but you are erasing the code after every time you scan yes? I'm thinking the pushrod, lifter, or rocker is now out of spec because or the rocker being loose. I would start replacing the valve train.
    97 Bonneville SE Not so much a 97 anymore
  6. #66 Re: help have engine knock.
    Feb 2013
    Amarillo
    Nighthwk I was thinkin the same. After looking at everything Im thinking its gotta be the lifter or a chipped piston. That's really the only thing I haven't looked at. And yea I've cleared the code after everything I 've done or replaced.. Thnx for reply. I'm really just debating if I wanna sink more money in this car or not. But I guess I need to just take all of it off and check to make sure. I got this car for 4K almost 5 years ago and its been pretty good for the most part. But all this little stuff popping up here and there are starting to add up.. Not sure if it's worth dumping more money into.
  7. #67 Re: help have engine knock.
    Mar 2013
    Milwaukee
    Quote Originally Posted by twentyocho View Post
    Well, why not, right? New valve train means modded rockers, lifters, retainers, valves, springs, and and cam! Yay! Might as well do the timing chain while you're in there. New piston means lots of work, though, so you might as well make that worth the time - forged pistons! H-rods! Heads! Rawr!!!
  8. #68 Re: help have engine knock.
    St. Louis
    You could just get away with replacing the valvetrain (or entire head), lifters and do the LIM gaskets while you're there and be good to go assuming the pistons are good. No need to replace the chain as they rarely have an issue. Being his work car I doubt there is a huge need for a forged bottom end (with another $400 for machine shop) and all that. Methinks his wife would probably put the kabosh on that idea real quick anyway, lol..
  1. 4th engine with rod knock
    By RideWithPride in forum General Grand Prix Discussion
    Last Post: 05-26-2013, 11:34 AM
  2. Engine Knock
    By chrisangelly1981 in forum Introductions/Noob Questions
    Last Post: 01-23-2013, 01:42 AM
  3. Engine knock???
    By MagnoliaMak in forum General Tech Discussion
    Last Post: 03-15-2011, 07:52 PM
  4. Need help, Engine Knock
    By valleyd01 in forum General Tech Discussion
    Last Post: 10-02-2009, 06:28 PM
  5. Do I have Engine knock?
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2008, 07:59 AM
