Thread: Engine Knock
Results 1 to 9 of 9
chrisangelly1981 Engine Knock 01-17-2013, 10:03 PM
01gpgt01 Re: Engine Knock 01-17-2013, 10:04 PM
chrisangelly1981 Re: Engine Knock 01-17-2013, 11:05 PM
SlowNA06 Re: Engine Knock 01-18-2013, 01:06 AM
dsmuts Re: Engine Knock 01-18-2013, 06:53 AM
chrisangelly1981 Re: Engine Knock 01-18-2013, 11:46 PM
sseilmnop It will run. Don't prevent... 01-19-2013, 02:07 AM
chrisangelly1981 Re: Engine Knock 01-23-2013, 01:39 AM
Bluemagic Junkyard is your cheapest and... 01-23-2013, 01:42 AM
  1. #1 Engine Knock
    Nov 2012
    Lebanon missouri
    Could uour engine on one of these newer cars knock without throwing any codes? It sounds like a bearing is bad the car has 125,000 miles on it. I have already replaced the the pullys to keep the belts tight because one of them where jumping. Does anyone know about how long the bearings last on the power stearing pump?
  2. #2 Re: Engine Knock
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    yeah it can knock with no code. It could be a bearing or a cracked flex plate. Mech stethoscope is what id start with
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: Engine Knock
    Nov 2012
    Lebanon missouri
    Ok so i just watched a video and I think it sounds more like the supercharger then a rod knocking but i am going to try to get a video of the sound up tomarrow.
  4. #4 Re: Engine Knock
    Pennsylvania
    Sounds like a shovel being dragged through gravel? supercharger bearing.
  5. #5 Re: Engine Knock
    Pull the sc belt off and see if it goes away
  6. #6 Re: Engine Knock
    Nov 2012
    Lebanon missouri
    I thought about that did not know if it would run with the belt off the supercharger.
    Mercer, Pa
    It will run. Don't prevent the supercharger pulley from spinning.
  8. #8 Re: Engine Knock
    Nov 2012
    Lebanon missouri
    Well it spun a bearing. Is there someplace i can get a performance short block from someone other then zzp?
    Dec 2010
    DMV
    Junkyard is your cheapest and work from there.
  1. 4th engine with rod knock
    By RideWithPride in forum General Grand Prix Discussion
    Last Post: 05-26-2013, 11:34 AM
  2. Need help engine knock??
    By thomasd2010 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-28-2012, 04:34 PM
  3. Engine Knock
    By tdm571 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-22-2011, 07:49 PM
  4. Engine knock???
    By MagnoliaMak in forum General Tech Discussion
    Last Post: 03-15-2011, 07:52 PM
  5. Need help, Engine Knock
    By valleyd01 in forum General Tech Discussion
    Last Post: 10-02-2009, 06:28 PM
