Thread: help have engine knock.
Results 1 to 20 of 68
  1. #1 Re: help have engine knock.
    Ohio
    if the sound goes away with when you raise the rpms it is probably the flexplate. you could also get under it and take the inspection cover off and shine a light up on the flexplate to see if you can see if its broken. it does not sound like a spun bearing/rod.
  2. #2 Re: help have engine knock.
    SE Level Member twentyocho's Avatar
    Feb 2013
    Amarillo
    Ok guys got a vid of it while idling then revd up a few times. Revd it up to 2500 then idled then 3000 then idle then 2500 to 3000 then off.. Not thinking its the flexplate as knock is pretty consistent.. Anyways here's the vid as promised hopefully it sheds some new light on the situation... Once again thnx again for all the help fellas..
    <iframe width="560" height="315" src="2000 GTP Engine Knock - YouTube" frameborder="0" allowfullscreen></iframe>
  3. #3 Re: help have engine knock.
    Listening right now.
    It's very consistent, very light. If you start up a bad bearing motor and rev quick to say 2500, just a quick throttle blip and let right off, there's typically a distinct banging on let off. Your vid it's consistent. More like one cylinder not firing.
    Do you have a scanner of any sort to look for misfires on one clylinder? Did you do any work to it recently? Sounds too nice and consistent.
  1. 4th engine with rod knock
    By RideWithPride in forum General Grand Prix Discussion
    Last Post: 05-26-2013, 11:34 AM
  2. Engine Knock
    By chrisangelly1981 in forum Introductions/Noob Questions
    Last Post: 01-23-2013, 01:42 AM
  3. Engine knock???
    By MagnoliaMak in forum General Tech Discussion
    Last Post: 03-15-2011, 07:52 PM
  4. Need help, Engine Knock
    By valleyd01 in forum General Tech Discussion
    Last Post: 10-02-2009, 06:28 PM
  5. Do I have Engine knock?
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2008, 07:59 AM
