Thread: help have engine knock.
Results 21 to 40 of 68
  1. #21 Re: help have engine knock.
    St. Louis
    Here's a vid of a broken valve spring for comparison: Broken exhaust valve spring on the #6 cylinder. In case anybody gets to this video and was wondering what the prob was.
    Grand Prix GTP - What a broken valve spring looks/sounds like - YouTube
  2. #22 Re: help have engine knock.
    Have you pulled the plugs to see which cylinder is acting up?
  3. #23 Re: help have engine knock.
    SE Level Member twentyocho's Avatar
    Feb 2013
    Amarillo
    No i haven't. Been in the house since weather has been gettin worse n worse..
  4. #24 Re: help have engine knock.
    Ontario
    Lifter tick?? Maybe??
  5. #25 Re: help have engine knock.
    Ohio
    No, I'm putting my money on a broken spring. Rod knock is very rattly sounding. It is very inconsistent.
  6. #26 Re: help have engine knock.
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    I had my sound like this. It was a grenaded lifter that wiped out the cam. You won't really know until you take apart the whole valve train until you find what is wrong
    97 Bonneville SE Not so much a 97 anymore
  7. #27 Re: help have engine knock.
    My comp g sounds like this
  8. #28 Re: help have engine knock.
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    valve tapping,
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  9. #29 Re: help have engine knock.
    Sep 2011
    Copperas Cove, TEXAS
    Yeah my thoughts are bad lifter or broken valve spring. Hope you get it fixed.
  10. #30 Re: help have engine knock.
    Pull the plugs. You'll see one that is different from the rest. Then you can aim after that cylinder.
  11. #31 Re: help have engine knock.
    Feb 2013
    Amarillo
    Well fellas I really do appreciate all the insight.. The more I've looked into it the more Im thinkin I have a bad lifter or spring but almost certain it is a lifter... I've gone through quite a few videos and doesnt sound like a bearing or rod.. Anyways I've determined the sound is loudest on front cylinder head so gonna pull the plugs and go from there.My question is will I have to pull the LIM to get the lifter changed if so i might as well do the LIM and replace all the lifters right..
  12. #32 Re: help have engine knock.
    Sep 2011
    Yeah, you have to pull the LIM to get the lifters out. You can do it, don't waste your money having a shop do it.
  13. #33 Re: help have engine knock.
    lifters = a lim job. and new valve cover gaskets and rocker nuts iirc
    lim gaskets are worth doing just because...but on the other hand i'd hope for a bad spring because depending on whats wrong with lifter it could take the cam with it. seems like you parked it right away, so theres hope.
  14. #34 Re: help have engine knock.
    Get a mechanics stethoscope and place it on the exhaust manifold on each cylinder until you hear it
  15. #35 Re: help have engine knock.
    Feb 2013
    Amarillo
    Heard noise right on start-up after having parked it just fine the night before thats why I was so confused about it so no I actually haven't driven it since. Its run maybe 8 to 10 minutes tops just for videos and to move car into my shop but not continuous for more than maybe 3 minutes at once. Was wondering wouldn't cam being damaged affect idle also? car actually idles fine.
  16. #36 Re: help have engine knock.
    Feb 2013
    Amarillo
    I used a long screwdriver and placed it on various parts of engine and sound is definitely loudest inside front valve cover mostly towards passenger side of head... but its definitely on top cause its louder up top than under car. Also checked pulley on blower thought maybe bad coupling but it's fine. If I remember correctly pulley would be loose when tugging from both sides inward and outward right? It shouldn't have any play right?
    Anyways Scotty I hope it is a spring or loose rocker so I can fix it then that way I can take my time to do the LIM job after getting everything I need to do it.
  17. #37 Re: help have engine knock.
    Feb 2013
    Amarillo
    Yea I planned to do it myself just didn't really want to though.. just replaced the suspension on my 4runner and was looking forward to just enjoying driving the Prix and parking the Runner.. It's weird cause I honestly have had some very nice cars but I've become really attached to this car.. Maybe it being my oldest sons first car before has something to do with it.. I've maintained it for the last 5 years cept for having a shop replace the AC blower thats it..
  18. #38 Re: help have engine knock.
    Feb 2013
    Amarillo
    Guys I'll be tearing into this hopefully by Tuesday. Gonna do the LIM gaskets, lifters, rockers, and springs... Also will be replacing elbows and water pump.. Any recomendations on springs, rockers, and lifters to replace the old stuff with will be appreciated.. If links are provided would be even better. If you guys can think of anything else let me know. I've been watchin the LIM and lifters video to get myself familiarized with the steps. Already got replacement coolant, oil and filter.. Hopefully everything looks good other than suspected springs so I can just get this done.. If anything else pops up I'll be sure to give you guys a heads up for opinions.. Thanks alot guys I'll get pics of process up as I go then order parts accordingly since not in a real rush. Wanna make sure to do this right...
  19. #39 Re: help have engine knock.
    its much cheaper to order your parts on line. only part that sucks is it can take a week to get your parts.
  20. #40 Re: help have engine knock.
    Feb 2013
    Amarillo
    Quote Originally Posted by FordMan77 View Post
    That really doesn't sound like a rod to me. Have you tried removing the S/C belt and starting it to see if the sound went away, or maybe both belts? If it's not a pulley then could be a rocker.
    Well guys first off want to thank each and everyone of you guys for all the great advice.. FordMan you hit the nail on the head and in all honesty most were pretty close in what was thought to be wrong. Anyways got all the crap out of the way and pulled the valve cover. To my great surprise everything looked great then I go to check the rockers and lo and behold one was loose as could be almost in exact spot where I mentioned previously to have pinpointed the noise.. Pics to show everyone just in case anyone is interested and hopefully the vids and pics can help someone else down the road.. Again thanks to all for all the help and i'll get pics up once my new headlights go on.. Oh and can someone tell me what to torque the rockers to. I was thinking 11 ft.lbs.... also what about vave covers.. Gonna get some stuff in the morning before putting it back together then seafoam for the ol'girl...
    ..and the culprit...
  1. 4th engine with rod knock
    By RideWithPride in forum General Grand Prix Discussion
    Last Post: 05-26-2013, 11:34 AM
  2. Engine Knock
    By chrisangelly1981 in forum Introductions/Noob Questions
    Last Post: 01-23-2013, 01:42 AM
  3. Engine knock???
    By MagnoliaMak in forum General Tech Discussion
    Last Post: 03-15-2011, 07:52 PM
  4. Need help, Engine Knock
    By valleyd01 in forum General Tech Discussion
    Last Post: 10-02-2009, 06:28 PM
  5. Do I have Engine knock?
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2008, 07:59 AM
