Thread: Turns Over But wont Start
Page 2 of 2 FirstFirst 12
Results 21 to 33 of 33
  1. #21 Re: Turns Over But wont Start
    You can do it and amber can help
  2. #22 Re: Turns Over But wont Start
    Dec 2012
    Port Huron
    lol thanks guys! Just didnt want to spend my shopping money/time on the damn car again! I will let you know what happens! Thanks again!
  3. #23 Re: Turns Over But wont Start
    Before I changed the pump. I'd be checking the fuel pump fuse.
  4. #24 Re: Turns Over But wont Start
    Dec 2012
    Port Huron
    Would the car still start up for a few seconds if the fuel pump was bad??
  5. #25 Re: Turns Over But wont Start
    Here's what I would have diagnosed this.
    1. Unplug the maf sensor and see if you can get it running. If it runs/runs better, it's a bad maf
    2. Check fuel pressure/fuel pump fuse.
    3. Go from there.
    You had the pressure checked and it appears the fuel pressure is questionable. Anything under 20psi and you can't start the car. It's not right that you can sometimes start it. So I'd be checking stuff closely.
  6. #26 Re: Turns Over But wont Start
    Dec 2012
    Port Huron
    The car just started again, but within 3 seconds quit running, I will check the MAF and go from there. Thank you
  7. #27 Re: Turns Over But wont Start
    Dec 2012
    Port Huron
    Nope MAF is good
  8. #28 Re: Turns Over But wont Start
    Then I'd think it's a pump. If it's starting at times, it's not a fuse. And you don't have a fuel pressure regulator on that year.
  9. #29 Re: Turns Over But wont Start
    Dec 2012
    Port Huron
    $314.99 for a new pump, trying to locate a parts store that actually carries the pump!
    I live here. DirtDog's Avatar
    Jun 2012
    That 300 and some dollars is for the whole pimp and regulator. The pump it's self shouldn't be to expensive
    Sent from my pager using Morse code. ... .. ... ....
  11. #31 Re: Turns Over But wont Start
    check Rockauto.com and use a discount code you find on google. Or if you have Advance locally.. find an online discount code (there's a thread on this forum, second post has the place to get the codes as a link) Best advance code I've used was something like $50 off $250 or more.
  12. #32 Re: Turns Over But wont Start
    Dec 2012
    Port Huron
    Every place I look sells the whole assembly kit! Im getting frustrated!
  13. #33 Re: Turns Over But wont Start
    ebay or amozon. you need to google, or search ebay for a part # for the your pump/car year make model, then hunt for the cheapest one.
  1. turns over fires back fires then wont start
    By flyby713 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-28-2011, 10:21 PM
  2. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  3. 1993 3.4 GTP turns over but wont start
    By mlang07 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-08-2010, 06:00 PM
  4. Engine turns over but will not start
    By rockytop104 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2010, 10:17 AM
  5. 00 GT wont start but turns over
    By dwagn313 in forum Introductions/Noob Questions
    Last Post: 06-18-2010, 06:30 PM
