Thread: Engine turns over but will not start
Results 1 to 2 of 2
  1. #1 Engine turns over but will not start
    Donating Users
    Knoxville, TN
    Engine Cranks but Will not Start
    Just recently got a 1998 Grand Prix SE from a family member. It was given to me as it quit running on them and they did not want to spend the time or money to repair!!! They gave it to me as they know I like to tinker with autos and other equipment
    Ran across this site and saw some very interesting posts! I thought this would
    be a great place to look for information. Have recently worked on the car and
    found the following:
    > Engine is a 3.8 naturally aspirated
    > Engine would crank but would not start
    > Could not hear fuel pump starting
    > Checked for fuel pressure on the fuel rail and had none
    > Had good spark from coil and from wires
    > Changed plugs
    > Replaced fuel pump
    > Removed injectors; cleaned and replaced "O-Rings"
    > Can hear fuel pump now and have fuel pressure at fuel rail
    > Engine turns over but still will not start
    Now I am wondering if I have a bad crank sensor or something or possibly
    a timing problem!!!!!
    Good to be a part of this forum and look forward to chatting some.
  2. #2 Re: Engine turns over but will not start
    Charles City, IA
    Do you have a scan tool at all? if so see if it has any codes, also does the tac move when you crank the car? If not you probably have a bad crank sensor.
    SMGPFC Two Nipple General
  1. Engine Cranks but Will not Start
    By rockytop104 in forum Introductions/Noob Questions
    Last Post: 10-04-2010, 08:21 PM
  2. 97 grand prix turns but no start
    By durleyeric in forum Introductions/Noob Questions
    Last Post: 07-27-2010, 07:13 PM
  3. 00 GT wont start but turns over
    By dwagn313 in forum Introductions/Noob Questions
    Last Post: 06-18-2010, 06:30 PM
  4. Car runs fine but doesn't start the first time i turn the key.. Needs a few turns..
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-28-2009, 02:18 AM
  5. engine will start only if
    By ryangtp89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2008, 07:34 PM
