Thread: Low boost, block off boost bypass solenoid. Full boost returns..
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21
    Ok throw it in the trunk it'll help weight distribution.
    04 Comp G.
  2. #22 Re: Low boost, block off boost bypass solenoid. Full boost returns..
    GT Level Member sic6's Avatar
    san marcos, tx
    Try to get it scanned. The scan tool should have a BCS PID to say if it is on or off.
    I know it is on when the car goes into reverse, so that it doesnt make boost.
    Might have a wiring issue or the pins are not making a good contact in the connector.
    97 GTP
  3. #23 Re: Low boost, block off boost bypass solenoid. Full boost returns..
    san marcos, tx
    I have an old red brick ,snap on scanner that allows me to turn the solenoid on or off to check its function.
    97 GTP
  4. #24 Re: Low boost, block off boost bypass solenoid. Full boost returns..
    Sep 2011
    Copperas Cove, TEXAS
    Hmm maybe one day I can cruise down to San Marcos and test it out. In March I plan on being home for a week. I live near Fort Hood, strait shot down 35.
  5. #25 Re: Low boost, block off boost bypass solenoid. Full boost returns..
    san marcos, tx
    Oh yeah that s not to far. The shop you took it to the first time should have done that to begin with. lol.
    Its got to be something crazy simple.
    97 GTP
  6. #26 Re: Low boost, block off boost bypass solenoid. Full boost returns..
    Sep 2011
    Shop?
    I do all my own work, I have never taken this car to a shop, other than Tint shop.
  7. #27 Re: Low boost, block off boost bypass solenoid. Full boost returns..
    May 2013
    Florida
    Quote Originally Posted by QUICKSILVER462 View Post
    I found the vent plugged on the BBV I solenoid on my car the day I drove it home after buying iy in 09'. It should have a little filter on the end of it, they get clogged with dirt over the miles and years. I removed the garbage and installed a 90 degree angle vacuum elbow on the end of it, cured the problem of not gatting full boost at WOT.
    How exactly did you clean this?
  8. #28 Re: Low boost, block off boost bypass solenoid. Full boost returns..
    Texas
    Quote Originally Posted by JPGgtp View Post
    It might be a good idea to pm him since this thread is older. He may not have subscribed to it and not know you are responding.
    85 Corvette
    01 TA
    03 Z06
  9. #29 Re: Low boost, block off boost bypass solenoid. Full boost returns..
    Aug 2016
    PA
    I registered literally to ask this question, but I think I'll take a good look around even though I don't have a GP ...
    Anyway... It seems to me that it should be fine to remove the solenoid all together and let my bypass valve vent itself into my engine compartment, is that correct?
    Mine failed, and rather then put a new one in I've just decided to delete it. I capped off the T connection to the solenoid, removed the electronic connection, and removed the connection from the Valve to the other side of the solenoid. I figure it either vents through the solenoid, or vents directly from the bypass valve nipple that used to run there...same/same?
    Someone let me know that I'm not going to explode anything? Lol
    Everything is running great, better than ever honestly... But I just wanted to make sure I'm understanding correctly and being safe. Love my car and def don't wanna destroy anything.
    Thank you to all replys
  10. #30 Re: Low boost, block off boost bypass solenoid. Full boost returns..
    Kemmerer, Wyoming
    sounds like you did it right.
  11. #31 Re: Low boost, block off boost bypass solenoid. Full boost returns..
    Sep 2011
    Quote Originally Posted by SgtMarshal View Post
    Thanks
  1. boost bypass
    By Erik Adam Rodriguez in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-06-2012, 02:06 PM
  2. boost bypass valve solenoid wiring
    By 97RS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-24-2011, 09:59 PM
  3. Boost Bypass mod
    By BADAZGTP in forum General Tech Discussion
    Last Post: 05-30-2008, 11:49 AM
  4. Boost Bypass Mod????
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2008, 11:04 AM
