Thread: Low boost, block off boost bypass solenoid. Full boost returns..
Results 1 to 20 of 31
  1. #1 Re: Low boost, block off boost bypass solenoid. Full boost returns..
    HUDSON
    I found the vent plugged on the BBV solenoid on my car the day I drove it home after buying iy in 09'. It should have a little filter on the end of it, they get clogged with dirt over the miles and years. I removed the garbage and installed a 90 degree angle vacuum elbow on the end of it, cured the problem of not gatting full boost at WOT.
  2. #2 Re: Low boost, block off boost bypass solenoid. Full boost returns..
    Sep 2011
    Copperas Cove, TEXAS
    Quote Originally Posted by QUICKSILVER462 View Post
    I figured that's what happened to my old BCS, so I bought a new BCS from the dealership. Thanks for the reply.
  3. #3 Re: Low boost, block off boost bypass solenoid. Full boost returns..
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    LOL nm just seen you did that i would say the ecm is causing it to not go full boost....i dont have it even hooked up on mine i just have the top of it hooked up so it still vents at idle
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  4. #4 Re: Low boost, block off boost bypass solenoid. Full boost returns..
    Sep 2011
    Quote Originally Posted by 00grandprixgtp View Post
    Which brings me to my 3 questions and also can a bad ECM cause these types of symptoms?
  5. #5 Re: Low boost, block off boost bypass solenoid. Full boost returns..
    Sep 2011
    Took pictures to show what I did.
    Cap off the "T" were the vacuum hose from the BCS goes to
    Unplug the BCS (electrical connection)
    Let this end of vacuum hose from BCS just sit/ lay there
    No tab for the BCS to bolt onto, came from ZZP that way
    Full picture to include the messed up paint from carb cleaner landing on the snout, not happy about that, but had to do it for possible leaks.
  1. boost bypass
    By Erik Adam Rodriguez in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-06-2012, 02:06 PM
  2. boost bypass valve solenoid wiring
    By 97RS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-24-2011, 09:59 PM
  3. Boost Bypass mod
    By BADAZGTP in forum General Tech Discussion
    Last Post: 05-30-2008, 11:49 AM
  4. Boost Bypass Mod????
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2008, 11:04 AM
