Thread: Problem- Almost completely solved.
Results 1 to 11 of 11
Threaded View
ABSGTP Problem- Almost completely... 12-10-2012, 03:14 PM
Scottydoggs Re: Problem 12-10-2012, 03:17 PM
ABSGTP Re: Problem 12-10-2012, 03:30 PM
dsmuts Re: Problem 12-10-2012, 06:33 PM
BillBoost37 Re: Problem 12-11-2012, 07:10 AM
ABSGTP Re: Problem 12-11-2012, 10:54 AM
BillBoost37 Re: Problem 12-11-2012, 11:24 AM
ABSGTP Re: Problem 12-11-2012, 03:21 PM
ABSGTP Re: Problem 12-13-2012, 08:05 AM
darkhorizon Re: Problem- Almost... 12-13-2012, 04:44 PM
MoarkatsINmuhtrailer Re: Problem- Almost... 12-13-2012, 04:50 PM
  1. #1 Problem- Almost completely solved.
    Apr 2012
    Cleveland, Ohio
    2000 GTP original motor spun bearing, replaced with a "recycled" motor. That motor was about to spin bearing and showed 12-15 hg vac at idle.
    Got another "recycled" motor just put it in and plugged in. Started and ran fine, after getting on the hwy it started to have a fit bucking, stumbling, and wouldn't stay running even in neutral at traffic lights.
    I checked/cleaned every ground(under hood), cleaned the positive connections, took apart and cleaned ICM and coils.- Also cleaned up the bracket on which the coil pack sits. Replaced battery bolts, both the alt, bat, and starter were checked and tested fine. I started it up and ran/idled perfect showing 17-20Hg vacuum. I let it sit idling while I picked up tools(5 min) drove away and within a mile it starts having a fit again which got worse as motor got warm. Once cooled down I switched out ICM and coils and barely started ran rough and showed about 12-15Hg of vac again!!!
    No SES lights but bat and oil.
    Oil level is fine.
    All vac lines are perfect.
    I am lost!! Any ideas?? I have searched the forum and haven't found the same symptoms has I have... Feel free to PM me.
  1. Is it a problem on my end? Picture Uploading Problem.
    By TJeno in forum Forum Bugs/Suggestions
    Last Post: 10-23-2012, 07:53 AM
  2. Problem with transmission NO REVERSE...Any suggestions of problem
    By newmy1d in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2012, 11:36 AM
  3. Oil Problem
    By Enzo354 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-07-2011, 07:41 AM
  4. Anyone ever have this problem??
    By Peirce1970 in forum General Tech Discussion
    Last Post: 06-10-2011, 05:02 PM
  5. hid problem?
    By grand2000prixgtp in forum Visual/Body Modifications
    Last Post: 05-12-2009, 02:34 PM
