Thread: Documented Build... L67
Page 1 of 3 123 LastLast
Results 1 to 20 of 43
  1. #1 Documented Build... L67
    SE Level Member JerzNick's Avatar
    Oct 2012
    New Jersey
    Not sure if this belongs here... But I thought it was fun to watch since I got 2 driving hours out of all the time and money...
    Build 2 in progress.
    '00 Grand Prix GTP First Build... Part 1 of 3 - YouTube
    Bored block, Eagle Crank, XP Cam, Ported Heads/LIM/Blower/TB, 3.0 Pulley, CAI, Headers, 42.5#, AL 104's, etc...
  2. #2 Re: Documented Build... L67
    Sep 2011
    Copperas Cove, TEXAS
    Very Nice, so why are Pacesetters a big waste of $$. I thought getting headers was a good thing.
  3. #3 Re: Documented Build... L67
    what you need to do now is, before anything else, you now need to go buy a set of sc rotors, cause you just killed yours, that black stuff was what was left of you rotor coating, and you took the rest off. now you will lose boost.
    everything else looks Jim dandy.
  4. #4 Re: Documented Build... L67
    Sep 2011
    So is this build before or after the motor in the video went BOOM? Still a cool video though.
  5. #5 Re: Documented Build... L67
    Oct 2012
    New Jersey
    Getting headers is a great thing. Pacesetter just happens to make garbage imo: terrible welds, low grade steel bolts etc...
    Not too worried about the blower rotors... Dropping in a L32, long block.
    Before, hence the part 2 coming soon.
  6. #6 Re: Documented Build... L67
    How can you not be worried about the rotor coating?
  7. #7 Re: Documented Build... L67
    Oct 2012
    New Jersey
    Because it takes all of 10 minutes to re-coat them.
  8. #8 Re: Documented Build... L67
    how does this re coating work? and what do you plan on using to coat them with?
  9. #9 Re: Documented Build... L67
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    I couldn't help but noticing it but does it say that you running an XP cam with 1.9 rockers??? If so that's gonna raise a few more questions.
    With the little thing in the video about "Do Not Use These (Comp Cam Lifters)" I take it that you think those are at fault.....I'm gonna lean more toward the fact that you were running XP along with 1.9's.....which would require a ton of machine work to the head and no matter what you'd do it would cause pre mature wearing of the valve guides.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
    Ohio
    Quote Originally Posted by Greg Badass View Post
    With the little thing in the video about "Do Not Use These (Comp Cam Lifters) I take it that you think those are at fault.....I'm gonna lean more toward the fact that you were running XP along with 1.9's.....which would require a ton of machine work to the head and no matter what you'd do it would cause pre mature wearing of the valve guides.
    ....... I bet the next thing said will be..
    Cuz racekar.
  11. #11 Re: Documented Build... L67
    Oct 2012
    New Jersey
    I wouldn't do them myself. There is a machine shop 3 blocks away from me that would do it for pretty cheap. Not sure what the material is, I can find out for you if you like? I wish I knew not to wire clean the rotors before hand, could have saved myself a lot of aggrevation :/ - I said not worried about it now cause the motor is junk. Plus the L32 I'm buying comes with Gen V powa
    Sorry, 1.6 Rockers (Aluminum) from ZZP. Not 1.9 - Will correct that.
    And not only are they loud, one of the lifters literally split in half...
    Quote Originally Posted by 99PGPGT View Post
    Cuz racekar.
    lol, Exactly.
  12. #12 Re: Documented Build... L67
    Probably plastidip or powdercoat them and tell you they'll be good to go.
    Pull rotors in a few thousand miles for whatever reason to find coating gone again...
    Machine shop runs away with your money
  13. #13 Re: Documented Build... L67
    He has new super rotors..
    If not..I'd toss him a whole charger I have sitting on the shelf in the way. Cause..he's local and going for painful waste of money #2... I er uh..mean build #2. Yeah.
  14. #14 Re: Documented Build... L67
    Oct 2012
    New Jersey
    Nail on the head.
  15. #15 Re: Documented Build... L67
    Been there...had two transmissions so I could rotate one out each time it broke.
  16. #16 Re: Documented Build... L67
    Pennsylvania
    Don't half of us do that with whole cars?
    Edit: Ahahahah. Oh man, just saw the pic of you drilling a hole to get the cam out. Hilariously brilliant way to avoid playing with dropping the cradle. Made my day.
  17. #17 Re: Documented Build... L67
    So you know why I bought the first Regal then?
  18. #18 Re: Documented Build... L67
    Pennsylvania
    Pretty transparent
  19. #19 Re: Documented Build... L67
    I live here. TLSheff's Avatar
    ... waiting for more.
  20. #20 Re: Documented Build... L67
    Oct 2012
    New Jersey
    Quote Originally Posted by SlowNA06 View Post
    lol, all that and now the motor is sitting in a tire on the floor
  1. ZZP XPZ Build
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2017, 09:40 PM
  2. HELP me with first gtp build
    By Jbruce308 in forum General Tech Discussion
    Last Post: 04-24-2012, 02:51 PM
  3. Too Slow, Time for a build (GEN V/N*/L32 Lim build)
    By AmericanSoldier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2012, 01:54 PM
  4. My Build
    By stlmo_gtp in forum Off Topic Discussion
    Last Post: 10-30-2010, 04:24 PM
  5. $400 gtp build
    By heavyRfoot in forum General Tech Discussion
    Last Post: 03-13-2010, 01:29 AM
