Thread: Turns Over But wont Start
Results 1 to 20 of 33
  1. #1 Turns Over But wont Start
    Dec 2012
    Port Huron
    Turned the car on to warm it up, 10 min later, jumped in, put it in drive and it stalled. Tried starting it again and it turns over but when you give it gas it does nothing but stalls, I dont even feel any pressure when it hit the gas pedal. Waited all night came out in the morning to try and restart it, did the exact same thing, started for a few seconds then stalled, now it just turns over. I have a half a tank of gas and dont smell any fuel, but I did smell exhaust last night. I am stranded!!!
  2. #2 Re: Turns Over But wont Start
    Dec 2012
    Port Huron
    Oh this is a 2004 grand prix gtp
  3. #3 Re: Turns Over But wont Start
    try this, it may be the fuel resistor
    post # 8, i cant post pics for some reason today... http://www.grandprixforums.net/fuel-...tor-68842.html
  4. #4 Re: Turns Over But wont Start
    Quote Originally Posted by ambersmom1819 View Post
    that bypass trick wont work on a 04, sorry.
  5. #5 Re: Turns Over But wont Start
    Pennsylvania
    Have you done any work to it recently? How many miles are on the car?
    Stab in the dark: It's starving for air. Open the airbox, check for a rat's nest. Make sure the throttlebody is not obstructed. Make sure there's nothing touching the wires inside the MAF sensor tube (the cylinder attached to the air box after the corrugated rubber tube on the throttlebody). Once saw the same thing from a feather stuck to the MAF sensor.
  6. #6 Re: Turns Over But wont Start
    could be the pump is priming, but not working after that. if it starts and stalls out. sputtering to a stall.
    id check the what the fuel pressure is at the rail.
  7. #7 Re: Turns Over But wont Start
    Dec 2012
    Port Huron
    This car has been a nightmare since I got it, it recently overheated and the coolant arm (?) was replaced, I dont know much about cars, I just google the symptoms and go from there and everything has come back to a fuel system problem. I do know that sometimes when I go to start it it has stalled right after I turned the key, but this time it refuses to start, just turning over. I will figure out where everything is and attempt at fixing this, thank you!
  8. #8 Re: Turns Over But wont Start
    Dec 2012
    Port Huron
    oh 178xxx miles
    I live here. DirtDog's Avatar
    Jun 2012
    Does it have fuel pressure at the fuel rails?
    Sent from my pager using Morse code. ... .. ... ....
  10. #10 Re: Turns Over But wont Start
    Pennsylvania
    178,000 miles without a fuel filter change might kill you. You may not be getting any fuel pressure. Unfortunately, none of the parts stores carry the 2004-2005 filter - you'll have to get one from a dealership. $15 part every 30,000 miles.
  11. #11 Re: Turns Over But wont Start
    Dec 2012
    Port Huron
    ok there is absolutely no fuel pressure, so I am assuming it is the fuel pressure regulator??
  12. #12 Re: Turns Over But wont Start
    most likely the fuel pump took a dump on ya, if you are up to it, you can just change the pump from inside the sender. its when you buy a whole new pump assembly they cost 200 and up. just the pump, 30 to 50.
  13. #13 Re: Turns Over But wont Start
    Pennsylvania
    Assuming can be tough.
  14. #14 Re: Turns Over But wont Start
    Dec 2012
    Port Huron
    Could a fuel pump relay be the problem?
  15. #15 Re: Turns Over But wont Start
    How do you know there is no fuel pressure?
  16. #16 Re: Turns Over But wont Start
    Dec 2012
    Port Huron
    a friend just tested it and got a zero reading
  17. #17 Re: Turns Over But wont Start
    It's most likely your fuel pump **** the bed. Do you hear the pump prime at all?
  18. #18 Re: Turns Over But wont Start
    Dec 2012
    Port Huron
    i honestly thought i did, but now im not hearing anything but I do smell gas when I turn it over, Im leaning towards a faulty fuel pump. And I know it isnt a cheap fix, plus a tow...Shoot me! Thanks for the help!
  19. #19 Re: Turns Over But wont Start
    you can change a fuel pump in 30 minutes on the side of the road if need be. very few tools are needed, and you get to it from inside the trunk.
    Very easy to change yourself
    04 Comp G.
  1. turns over fires back fires then wont start
    By flyby713 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-28-2011, 10:21 PM
  2. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  3. 1993 3.4 GTP turns over but wont start
    By mlang07 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-08-2010, 06:00 PM
  4. Engine turns over but will not start
    By rockytop104 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2010, 10:17 AM
  5. 00 GT wont start but turns over
    By dwagn313 in forum Introductions/Noob Questions
    Last Post: 06-18-2010, 06:30 PM
