Thread: Turns Over But wont Start
Results 1 to 20 of 33
  1. #1 Re: Turns Over But wont Start
    Pennsylvania
    Have you done any work to it recently? How many miles are on the car?
    Stab in the dark: It's starving for air. Open the airbox, check for a rat's nest. Make sure the throttlebody is not obstructed. Make sure there's nothing touching the wires inside the MAF sensor tube (the cylinder attached to the air box after the corrugated rubber tube on the throttlebody). Once saw the same thing from a feather stuck to the MAF sensor.
  2. #2 Re: Turns Over But wont Start
    Dec 2012
    Port Huron
    This car has been a nightmare since I got it, it recently overheated and the coolant arm (?) was replaced, I dont know much about cars, I just google the symptoms and go from there and everything has come back to a fuel system problem. I do know that sometimes when I go to start it it has stalled right after I turned the key, but this time it refuses to start, just turning over. I will figure out where everything is and attempt at fixing this, thank you!
  3. #3 Re: Turns Over But wont Start
    Dec 2012
    Port Huron
    oh 178xxx miles
  1. turns over fires back fires then wont start
    By flyby713 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-28-2011, 10:21 PM
  2. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  3. 1993 3.4 GTP turns over but wont start
    By mlang07 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-08-2010, 06:00 PM
  4. Engine turns over but will not start
    By rockytop104 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2010, 10:17 AM
  5. 00 GT wont start but turns over
    By dwagn313 in forum Introductions/Noob Questions
    Last Post: 06-18-2010, 06:30 PM
